Water will not intake in a Kemore front load washer. Waters is on and we confirmed hoses and water lines clear
    President:
  • 1,185 Answers
Have you removed the hose supplying the machine to check if the filter inside the inlet valve is blocked , or fo that matter is water being supplied down the hose?
Remember that the hose will be under mains pressure so have a towel handy when you remove the connector.
If it is clean then leave the hose off place your finger on the plastic thread of the inlet valve and get someone to set the machine going
You should feel a slight vibration if the coil which switches the water inlet valve on is being activated (Some of them really make a strong buzzing noise)
There is no electricity in that area so do not be frightened to put your finger on it.
If the filter is clean and the coil is buzzing you should get water going into the machine.
If the coil is not buzzing it has gone open circuit and needs replacing.
Worst case is that the programmer has broken (Very rare)
Posted on May 23, 2009
Washer will not fill up with water
Is water switched on? Is water reaching soap drawer? If it is then there is a blockage in the soap drawer hose to the drum, if no water is getting here check the filters at the water intake valves are not blocked where the feed pipes fit. If these are clear try a cold wash setting to see if you get water filling, if you do then it may be a faulty hot water intake valve.
Jan 01, 2013 | Samsung WF337AA Front Load Washer
Washer not draining
"F20" on display
(Water Inlet Problem-no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Nov 20, 2012 | Kenmore HE2 Plus Front Load Washer
My Kenmore Elite HE5T front loading washer is giving me an F20 (Water inlet problem - no water or insufficient water supply) code. The Drum fills half way up with water in about 5 minutes and then the...
The F20 error deals with the water coming into the tub. The F20 code indicates the control didn't see any water enter the tub.
  1. There is a flow meter that tells the control water is coming into the washer. If the flow meter is faulty the error usually happens quickly.
  2. Near the pressure switch is a clear plastic hose may be kinked or even have a small hole in it. Check the drain line first and then remove the top of the washer to access the pressure switch and pressure hose. With the washer empty remove the hose from the pressure switch located on the right side of the washer and blow through it to clear any debris blocking the pressure hose or air trap.
  3. If this doesn't help then most likely you will need to replace the pressure switch.
Feb 25, 2011 | Kenmore Elite 45986 Front Load Washer
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
I have an frigidaire front load Mod.# GLTF2940ESO with an recurring E10 error message. HELP!!
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Apr 11, 2010 | Frigidaire GLTF2940ES Front Load Washer
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
We just bought our Samsung WF409. It won't even do a load without showing the NF signal. We've checked all hoses, etc. The water seems to be going in fine. However, the washer doesn't seem to register that...
NF is a water supply error. The waters supply valves are malfunction or there is something in the hoses blocking the water. Turn the water off and disconnect them and see if there is anything obstructing the water.
Dec 18, 2009 | Samsung WF337AA Front Load Washer
Need to drain the water out of the washer machine
take off the back panel
two 1/4 in screws
just inside you will see the pump
remove either of the two hose and the entire machine will drain...
Oct 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washer is showing a code
    • Opening the faucet and watch for running water if you have water
  3. Can be caused by bad pressure switch
  4. Can also be caused by clogged pump
  5. also by too low of a drain hose height.
    Check for clean filters of the inlet water line.
    Check that the drain hose was assembled as per the manual's instructions.
May 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity Front load washer, Starts to Fill, then Flashes E10, Was wondering what this code is referring to
May 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
