Question about Tascam 2488 Portastudio Multitrack Recorder System
Tascam 2488 will not reload a 2 cd back-up. A friend of mine downloaded his master and sent me the master cds. It spanned two CDs. However, when I tried to upload to the sam tascam 2488 model, my 2488 is unable to complete the upload process and ends the session. My associate and I have the same tascam 2488 model. (not the MKII).
    Problem Solver:
  • 6 Answers
Have you tried loading it to your pc, then connect via the 2488 usb and try to retrieve it that way.
Posted on Oct 23, 2007
Can't figure out how to mix down tracks to stero master on 2488 mk 2
Your owners manual can be found at manualslib.com by searching your model number and choosing manualslib under the heading TASCAM 2488MKII OWNER'S MANUAL Pdf Download.
Tascam has a help line at 323-727-7617. If you haven't done your homework in deciphering the users manual, I would not call them. Their service is free, but their on phone time for help is limited and they can be quite surly.
Dec 16, 2017 | Tascam Audio Players & Recorders
How to download from the Tascam 788 to the CD Burner?
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Chapter 8
Feb 04, 2011 | Tascam 2488 Portastudio Multitrack...
On my tascam 2488 neo, ive recorded a song that is 2min16sec. i set my in at zero and out at 2min23. i hit mixdown and then try to hit play and record and the record button will not light up or actually...
I think if you had the manual you would know the answer to the last question.
Tracks must be a minimum of 4 seconds long (page 118)
Jan 28, 2011 | Tascam 2488 Portastudio Multitrack...
I have Print Master Platinum 15- 5 CDs only - no paperwork
The install is pretty straight forward. Just start with disc one or disc labeled install cd (or similar) The manual is just guidance and not needed unless you prefer to reference to it. If you do need it you can visit the support section of the Print Master website to download a new copy.
Thanks Live-Tech 1-888-361-8511
http://www.mylive-tech.com
Jan 29, 2010 | Broderbund PrintMaster Platinum 15 Full...
Overall volume when burned to disc is too low
This is a pretty common complaint and not unique to the 2488. The basic idea is that commercial CDs get their superior volume levels through the use of lots of compression which occurs throughout the mixing and mastering process. There are lots of schools of thought on how and when to apply compression during the production of recordings and the only real way to learn is to read up on compression and then to experiment.
Having said that, volume can also be increased by normalizing but many people don't consider that to be a completely legitimate way to increase dynamics and it does require working with wav files on a PC as opposed to the 2488.
I use a combination of external compressors, software applications, and the 2488 onboard compression effects when mixing/mastering (but mostly ouboard compressors). I usually don't burn CDs from the 2488 and choose to instead tweak the final mixes from the 2488 on my PC using various programs which gives me better control over various parameters (such as applying normalization to all tracks at once).
So the short answer is that there a lots of different ways to get there but basically when the dynamic range or your recorded material is large, the main volume of a track is going to sound lower because the parts with the highest levels (peaks) are going to need to fit in the -0 db area in order not to clip. When compression is applied the dynamic range is squashed down so that the peaks are brought more in line with the audio level which makes up the main portion of the track (in the middle of the dynamic range). This then allows the overall levels to be brought up higher without the peaks clipping. This is called downward compression.
Compressors can also be used to bring up the levels of low volume sounds without affecting the middle and higher level audio. This is called upward compression and also compresses the dynamic range in order to raise the volume of lower levels audio. This is called upward compression.
So when compressing and then boosting the main levels, the noise floor can come up with it. That is why gating is also commonly used along with compression and most outboard compressors are gates as well.
Hope this helps.
bd.
Nov 10, 2008 | Tascam 2488 Portastudio Multitrack...
DP-01FX/CD sound quality of CDs
Nothing really specific other than to make sure you are recording as close to 0 db as possible without going over. Your master fader also needs to be set at 0db or above as this effects the volume when mastering.
Commercial CDs use a lot of compression to attain volume levels which aren't attainable without it. You should however be able to reproduce onto CD the volume levels you are hearing on your Tascam without resorting to compression.
To troubleshoot, you might want to try exporting your master tracks as wav files onto your computer via usb and then listening to them there. If the volume is low there you aren't creating master tracks with good volume (see above: master fader level), if the tracks sound good as wavs on your PC, then burn them onto a cd from there. If that CD has proper volume then you may have some problem with your Tascam CD burner although I've never seen a situation where a burner actually caused low volume like this.
Best of luck.
BD
Apr 21, 2008 | Tascam DP01 All-In-One Recording Package...
Uploading audio instumentals into the Tascam 2488 II
You can get to the quick start guide here.
www.tascamgiga.com/i-738-232-128-0-BBDFF677.pdf
There is quite a bit to learn to get to the proficient point with this unit. Most of it involves the operator learning the software
Feb 11, 2008 | Tascam 2488 Portastudio Multitrack...
Don't know how to Pre-Master or Burn to CD, please help me!
Don Q -
This answer assumes you have the 2488 mkI and not the newer mkII because the process may differ slightly on the mkII.
To premaster you first have to set an out point for the end of your pre-master (the start point is always zero). Go to the 'Audio CD' menu item and choose 'pre-master' under that. You'll see the word 'mastering' appear in the top left of the screen to let you know you've entered mastering mode. Make sure you have the tracks unmuted that you want to mix into the pre-master and have all of your eq, panning, etc set the way you want. Then hit record and play. The pre-master records to a stereo pair of dedicated internal tracks. You can redo the premaster as many times as you like which will overwrite those internal premaster tracks. You can clone the premastered tracks to a stereo pair of tracks, export them as waves or burn them to a CDR.
fnawesomewes - You have to press record and play to record your premaster.
Dec 07, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
136 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
