Compressor will not turn on,
The temp in the house went from 68 to 75 in about 45 mins, had no notice that there was a problem. Compressor was hot, have tried to hard start it and tested all wires, nothing will get the compressor to start.
  • MrRepairAll May 11, 2010
    Have you checked the fuse panel?
    Problem Solver:
  • 6 Answers
Id say she is burnt up.
Posted on May 23, 2009
My 2002 TB a/c works for 20 min. Then does not. Checked , no leaks, clutch turns, condenser clicks until blowing hot air, replaced low pressure switch
Something to check because this has happened to me.....Make sure you have enough coolant in the radiator/overflow tank. IF the engine is running hot, the thermal switch on the AC compressor will turn it off to protect the compressor from overheating and damaging it. Don't go by the guage in the dash, it's usless. Hook up a scan tool and get the exact temp. Shouldn't be over 210 which is normal operating temp.
Aug 05, 2015 | 2002 Chevrolet TrailBlazer
I own a Fogel Fridge Model # VR-17-RE-PR Recently
Richard,
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 12, 2013 | Refrigerators
Subzero r601 compressor not turning on
Check the relay on the compressor. Pull it off and shake it. If it rattles, it is bad.
Dec 07, 2012 | Refrigerators
I have a Kenmore model 106.58964700 that both the freezer and refrigerator stopped working. The service technician said it was the start relay (Sears part number 2319792). I replaced the part with one...
Daleb870, Compressors on referigators run hot to the touch. You are experinceing a couple diffrent issues. First off 0 and 36 is a very ideal temp. The compressor and tubing are most likely hotter than normal as it was trying to cool down a fridge that was house temperature. After the fridge runs for a while and the load on the fridge is equalized the tubing will not be quite as hot. It and the compressor will still be very hot to the touch. The compressor its self right aroung 130f. But its normal.
Sep 01, 2011 | Refrigerators
My freezer is working fine, but my compressor is hot to the touch. Is the compressor too hot? I have converted my freezer to a kegerator with a temp. regulator. I do not want to burn my house down or...
the compressor will run hot,but you should be able to touch it without burning yourself.(when you compress a gas, heat is generated as it turns to liquid and when it expands back to a gas it absorbs heat,the principal of a fridge...)
Oct 23, 2010 | GE Freezers
We have a Brisk Air in our 1991 Jayco Eagle. The travel trailer is from Rhode Island and we're not sure if the air was ever used. The unit turns on, the compressor engages but doesn't blow cold air, only...
Really sounds like the compressor isn't coming on. Go on top of camper and take the housing off. Now then engage the air conditioner and feel the compressor. Touch the copper lines to feel any temp. change. Now then if it isn't coming on look for the capacitor. Silver looking can that is the item to check. They are duel purpose they run the fan and the compressor. Unplug the electricity and remove the capacitor remembering the wires and were they went. Now take to parts house and they will be glad to check it. Should only cost about 15 bucks for new one. Get the same rated size. be good to go. ken
Sep 15, 2010 | Dometic Rooftop RV Air Conditioner
Yesterday, my dad brought me a working GE upright freezer from his house, transport time about 45 minutes. The freezer was working fine before he left his house, he did tip it little bit to load, unload...
You should try to un-plug the freezer and let it stand up-right over night to re-settle the freon back down inside of the compressor.
The compressor should normally get hot if it is doing it's job right, and there is a starter for the compressor motor (usually it looks like a large capacitor) that could have failed, or the defrost timer (if it has one) could be stuck, and you should be able to see the small dial on the defrost timer slowly turning, and if it does not turn, then replace the defrost timer.
Jun 07, 2010 | GE 13.7 cu. ft. General Electric Upright...
Kenmore Refrigerator - The refrigerator, which as purchased in 2002, stopped working yesterday. We had a cleaner clean the house - she pulled out the fridge, and cleaned under and inside fridge - we...
good checks,
one or two more
is the fan next to the compressor working
ar the coils by the comprssor clean
and one lasrt thing
there is a block on the compressor, unplug the unit pop that block off and shake it if it rattles there you go
Oct 04, 2009 | Refrigerators
MODEL PH15K5SA-5 wHEN COMPRESSOR GETS HOT UNIT SHUTS OFF. wILL RESTART IN 10 MIN.
You have a control that sencors Temp of the compressor - normally this happens when the winding in the compressor go bad, first clean unit completely then replace the bi Metal on the compressor - or replace the compressor if worth it ??.
Jul 17, 2009 | Friedrich WallMaster WS07A10D Air...
Air conditioner compressor keeps shutting down
This is due to thermal overload,Which can be caused by low oil in the compressor,the fan has stopped running on the unit outside,Dirty coils,or just a worn out compressor.Although this is thermal overload,It has nothing to do with outside temperature,But rather the internal temperature of the compressor itself.
May 19, 2009 | LG Heating & Cooling
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
