Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error code F9 for kenmore elite washing machine He3T
My washer won't finish the cycle, unlock the door or let me fix the problem. What is the best way to fix the situation on a budget???
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
It will not let you unlock the door because the machines full of water?--the machine will not finish its cycle because the vacume switch is still detecting water , The water will not drain because the pump is blocked with something , probably a wire from your underwire bra,all you can do is undo a pipe undernieth and let the water drain away and take the pump to bits ?There may be an inspection cap somewhere on the front at the bottom
Posted on May 23, 2009
Hi! We have Kenmore Elite he3t. We noticed water in the washer today after a complete cycle so we ran the rinse and drain command on it. I tried to begin a new load on a normal wash cycle and it will...
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite HE3T washing machine code F11
Kenmore Elite HE3T washing machine error code F28, what does this mean?
Jun 26, 2009 | Kenmore Elite 45986 Front Load Washer
WHAT IS DU?
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • May 19, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite Washing machine error codes
    I am getting F35 error code. What is the problem?
    Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite HE3t model 42922
    After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
    Aug 12, 2008 | Kenmore 46462 Front Load Washer
    ERROR CODE
    Here are the steps to unlocking the door manually if clothes are still in the machine.
    1.Unplug machine
    2.remove bottom panel
    3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
    4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
    5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
    6. You may now open the door.
    This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
    Mar 29, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
    Kenmore elite HE3t
    I am getting an F35 code on the washer has anyone had this problem
    Sep 21, 2007 | Kenmore Elite 45986 Front Load Washer
    Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
    826 people viewed this question
    fordexpert
    Mike Squire
    Robert Rankin
