Question about Epson Office Equipment & Supplies
Ink carriage not working properly
Just received an epson stylist r280. I was trying to set it up and the ink carriage will not go to the open spot in the housing to add the ink. Nothing is blocking the movement. The power light goes off and the paper and ink lights flash.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
This is a common error whith this printer, if you keep on trying it WILL return to the (exchange ink) position eventually ,however,Another neat trick , When you try to change ink and the thing moves unplug the mains power cable , once you have done this the cartridge will be unlocked and will move freely anyway,, move it by hand and install the ink you have,
Posted on May 23, 2009
What is wrong with my Epson R280 printer when the ink appears smeared down columns of a spreadheet
Probably dirty heads on the nozzle. In most inkjets there is a maintenance option to clean the heads. I would first clean the heads, and then make sure that the print heads were aligned. If that is all squared away then check for any driver or firmware updates. Finally get some rubbing alcohol and gently clean the print head. Sometimes if the printer is not used that often the ink will congeal and smear.
Oct 19, 2014 | Epson Stylus Photo R280 Series
My Epson stylus Photo R280 prints like its printing double and is very unclear..how do I correct this problem
You need to align/clean your ink cartridge. Look under the Printers, select your printer and go to Properties. There should be a tab for maintenance.
Feb 16, 2013 | Epson Stylus Photo R280 Series
I have a Epson Stylus nx200 brand new, and am having a hard time installing the ink. I do what it says but the part where I am supposed to put the ink won't slide over into the appropriate spot. Please...
turn it on, flip open the panel to get to the ink, press and hold the ink botton under the paper feeding botton, it'll start to move, then when it slides over press the ink botton, it'll shift, continue to press it till it slides to the open area for your ink to be installed
Oct 18, 2009 | Epson Stylus NX200 Printer
Epson stylus photo R280 won't print due to false low on ink
Try using a soft cloth saturated with rubbing alcohol over the metal contacts. Make certain all residue to include spent ink or oil from your fingers have been removed. Let air dry. If your printers Print Head can be removed separately, that is the way to go when cleaning components. It has been known that Print Heads fail also and need replacement.
Feb 07, 2018 | Epson Stylus Photo R220 InkJet Printer
Problem with One Color (Yellow) not printing on Epson R280
Hello sir; Why don't try to press "resume" key before you print.
Apr 17, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Epson Stylus Photo R220 InkJet Printer
Ink carriage jammed
Well, I'm not too happy that the only response I got was solicitation for the Premium Assistance Plan.
Figuring that the printer had pretty much died, I allowed my husband, Mr. Fix-It, to give it a try. He simply pushed up on the front end of the ink carrier and slid it into the opening. This allowed him to get at the cartridges and push gently down on the new cartridge I'd installed. It had not been seated completely. Works fine now.
I'd be curious to know why I found a huge ink spot under the printer. It has probably been there for quite some time, as I usually just dust around things rather than move them.
Mar 14, 2008 | Epson Stylus C84 InkJet Printer
145 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
