Question about Garden
Won't stay running
My husband is using a chainsaw or trying too. I know nothing about this so bare with me. When he pulls the handle thingy to start it, it will start and hold for about 5 seconds max, than cut off. It almost sounds like a car flooding with gas. It is full of gas. It also looks like when it goes to recoil, it punches the handle back out and thats when it dies. i know thats not very helpfull but any ideas?
  • 46 Answers
Every year the spark plug must be replaced on chainsaws for the best performance.
So your current plug is probably fouled or has an incorrect gap from last years use.
Record your chainsaw's make and model number then go to your local large hardware store and to the lawn area, they will have a replacement spark plug. And if you don't have a ratcheting socket wrench set with spark plug removal socket, this is a great time to get one. the size will be 5/8 inch.
Always use Safety glasses and ear protection.
Posted on May 23, 2009
Will fire,wont stay running.wants to be full choked,open choke,it dies
Jerry, First thing to get is a new plug gaped correctly and try. Could need carb. adjustment, fuel filter replaced, bad fuel line(cracked/pinched), Dirt/faulty diaphragm in carb. plugged spark arrester in muffler,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://answers.yahoo.com/question/index?qid=20090528073906AA0y882
Chainsaw will only run with choke
Stihl Chainsaw starts but won run
http://tekindoor.com/miscellaneous/stihl-chainsaw-troubleshooting
May 28, 2016 | Garden
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
My Husqvarna starts but won't accelerate when you pull the trigger, acts like the brake is on but the handle is in the free position.
It may be running very rich, make sure the air filter is clean, if ok. check the spark arrestor in the muffler outlet ( if fitted ) has not carboned up, if ok, check the exhaust port is not blocked with carbon.
Dec 30, 2012 | Husqvarna 445 18" 45.7 Cc Chainsaw...
Spear and jackson, sht26X, the throttle won't
I suggest taking the handle apart to see if anthing is blocking the action of the trigger from inside, like some debris. Then see if the throttle cable moves if you pull it. If necessary keep tracking it back to the carburetor, maybe there is a piece of debris in there blocking the throttle lever on the carburetor.
Sep 16, 2011 | Garden
Runs but the chain won't move? Poulan
This sounds loke the chainbrake has activated, grab the hand guard and pull it fimly fully back to the top handle until it clicks and the brake is of, now try again.
Aug 28, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a McCulloch 14" Mini P52 which belongs to
If this machine has a saftey chainbrake it may well have activated, to de activate grab the front hand guard and pull it fimly back to the top handle of the saw, this will de activate the brake, now try again.
Aug 28, 2011 | McCulloch Garden
The chainsaw starts easily. But the chain won't move at all.
Sounds like the chainbrake has activated, grab the hand guard and pull it firmly back to the top handle, until you hear an audible click as the brake loads, now try again.
Aug 04, 2011 | Poulan 14" Chainsaw
My chainsaw wont start. electric souce is good, but nothing happens when you press the trigger.
Check the chainbrake is fully pulled back to the top handle, many electric saws have a micro switch to prevent the saw from running with the brake on.
Jul 16, 2011 | Mcculloch 16" Electric Chain Saw Mcc3516f
2nd use of chainsaw pp3516avx, it won't start, choke lever will not stay extended. I followed the instructions to start and nothing works
The choke system is connected to the half throttle position, if you lift the throttle trigger the choke pull will automatically return, whilst trying to start do not lift the throttle trigger, the starting procedure is, pump the primer bulb as many times as it takes to 3/4 fill the bulb, pull the choke pull fully out, this will switch the saw on and engage the half throttle, crank the engine until it fires once, do not continue to pull,it will actually not run on full choke, if you do continue to crank with the choke fully out, you will very quickly flood the engine, now push the choke fully in, now crank the engine until it fires up, lift the throttle trigger once, this will dissengage the half throttle, and it should now come down to idle.
Mar 19, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
169 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
