Question about HP PSC 2175 All-In-One InkJet Printer
HP psc 2175 all inone printer
The printer will not scan.  I press start once, nothing happens. I press start again it says busy.  Eventually a message shows saying printer and computer not connected.  It may say to re-install something.  I unplugged the cords and that did not help.  It used to work.  The ports seem loose inside the tower.
  • 2 more comments
  • Tatoworm Oct 28, 2007
    I don't understand your system. You advertise a solution, but all I see is a comment that someone else has the same problem.
  • cortnid Dec 05, 2007
    I have been trying to scan all morning long. I have re installed the printer 2 times and it still wont scan. It says there is no connection but the printer works fine.
  • debrak Dec 08, 2007
    will not scan - says no scann options, need to install software
  • Anonymous Jan 31, 2008
    I have the same problem has anyone found a solution?
When I press to print, the previous screen comes on and then it does not print. Any suggestions think you.
Posted on Feb 10, 2008
My hp 2175 printer/scanner now shows up as hp 2170 and will not scan
heres wht u can do.. go to www.support.hp.com enter the model no. of ur printer and search for drivers.. on the next page.. choose support and driver and 1) Update drivers for the printer.. 2) download drivers as per OS of ur computer.. Uninstall the printer from the computer.. start installing the printer again.. but do not plug the USB device to the computer till it prompts u to.. once this is done the issue would be resolved..
let me know if this was useful to u regards, guru
May 06, 2010 | HP PSC 2175 All-In-One InkJet Printer
I switched from a dial-up connection to DSL, and when I tried to print something, nothing happened. The printer is on and acts like it will print, but nothing happens. Help?
I had this problem once before after changing ink cartridges, and I came to this site for help. I knew that I was supposed to press two buttons at the same time, but I could not remember which two. After reading a post here, I was reminded that the two buttons that must be pressed at the same time are "setup" and "options." It worked once again under these new circumstances. Thanks Again!
Nov 07, 2009 | HP PSC 2175 All-In-One InkJet Printer
My HP 2175 started knocking, won't copy
Try pulling the cartridge out and re-install a couple of times, also check to see if everything is clean inside printer, paper scraps can get into things and cause trouble
Aug 22, 2009 | HP PSC 2175 All-In-One InkJet Printer
My hp psc 2175 all-in-one keeps giving me the message "press enter to align cartridges." When I do that it says" printing align cartrigdes page" then it says "alignment cancelled" and then goes back t
Hello Dear; When you install new cartridge the machine going to alignment it is neccessary you just follow the direction step by step to finished the procedure.
Apr 28, 2009 | HP PSC 2175 All-In-One InkJet Printer
My HP PSC 2175 ALL IN ONE DOES NOT SCAN!PLEASE HELP!
I assume you have Vista and when the scan button is pressed on the product, nothing happens. The scan button does not work correctly. Workaround
Choose one of the following options to scan without using the scan button. Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif), click Programs, and then click Windows Fax and Scan.
    NOTE: The Windows Fax and Scanoption is available in the Business, Ultimate, and Enterprise editionsof Windows Vista. If you have the Home Basic or Home Premium edition ofWindows Vista, skip to Option two: Scan using Paint.
  2. Click New scan.
  3. Click File, and then click Scan.
  1. Click the Windows icon (c01319360.gif), click Programs, and then click Accessories.
  2. Click Paint.
  3. Click File, and then click From Scanner or Camera.
  4. Click Scan.
Cause The drivers in the Windows Vista operating system do not support button press functionality on the product.
Apr 20, 2009 | HP PSC 2175 All-In-One InkJet Printer
Align cartridges
You could try to get out of this mode
Press & hold SETUP than press COPY OPTIONS
Feb 22, 2009 | HP PSC 2175 All-In-One InkJet Printer
Hp printer won't copy
1. turn off / on the printer
2. press setup hold down and press options
3. press start color copy
worked for me on psc 2175
Sue
Jan 17, 2008 | HP PSC 2175 All-In-One InkJet Printer
Problems
Switch the unit. let it rest for half an hour. While it is resting check the manual for any 'faults' list. Look for a 'reset' command - may be mean pressing several buttons while the machine is off and then with the buttons still pressed switch on the machine[you may need two hands and a nose or three hands for this ;-)] If still out of luck go to places for further info HP technical support team or www,fixyourownprinter.com
Jul 05, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
