Question about Lexmark X2350 All-In-One InkJet Printer
Blue light flash cartrige bangs one end to other then light flashes still, all clear have cheaked
My blue light keeps flashing its nothing to do with paper and when i press power button its slides from one side and back fast and load and keeps flashing any ideas?
  • Lexmark Expert
  • 228 Answers
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Posted on May 23, 2009
Bosch classixx tumble drier lights flash
The lights are flashing as an error code? what lights are lit/flashing, what rate of flashing etc? more information may help sort this faster
Mar 24, 2014 | Dryers
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
I have 8 flashes on my Panasonic TCP60S30 - 60" Plasma.. Does anyone know what this problem is or how to fix it? I heard a big bang then screen went black, now I keep seeing 8 red light flashes.
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit). This is the fault. Can you follow? Just check this site, and see whether it help you. It has details about the blinking codes and fault locations to Panasonic Plasmas.
Jan 14, 2013 | Panasonic TCP60S30 Plasma TV
Flashing blue light
1. turn it off2. hold centre button until blinking blue and red3. briefly press volume down4. turn it off= fixed :)
From Sennheiser UK:http://www.sennheiser.co.uk/uk/home_en.nsf/root/contact_menu_technical-question_telephone_headsets_faqs_mm400_series_bluelight
Jun 19, 2012 | Sennheiser MM 550 Wireless Headphones
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
Cheak engine soon light keeps flashing
Is the car missing or not running quite right, have a little more wiggle to it? Flashing check engine light is usually indications of a cylinder misfiring which could be caused by a few different things.
Aug 05, 2010 | 2003 Mercury Mountaineer
Have just changed refilled cartrige, alarm light is blinking
The printer does a longer green flash and then the amber flashes. you need to tell me how many flashes between the green flashes, to know what the problem is.
Aug 13, 2009 | Canon PIXMA iP1600 Printer
Neptune dryer does not produce heat md5500
Did you cheak for dead short by touching one end of the element and one end on the heater housing?if there is continuity then you have a dead short .The lint is normal just clean it out.You may have a bad insultor that the element runs true in the heater housing.Also cheak the wires for dead short very carfully with flash light hope this helped:)
May 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
"Lock on" light keeps flashing - cannot run dishwasher
same issue..
Other boards suggested heating element issue - but nothing very clear or compelte.
Aug 10, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Lexmark X2350 All-In-One InkJet Printer Logo
298 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
