Question about Maytag Performa PAV2200
Maytag Performa PYE2200AYW - not working
My dryer stopped last night mid cycle.  Now it is totally dead.  I have power to it, timer will tick, but no heat, no spinning, no motor hum.  I took it apart to tinker with it and found nothing really, other than it was surprisingly clean.  Belt looked very good.  I estimate it to be around 8 years old.  My question is, is there a fuse or do you think the motor blew?  I noticed if you flip up the top, in the back there looks to be a black circular, about the size of a quarter, fuse looking thing, and to the right of that is a white 1 inch rectangular fuse looking thing.  Are these replaceable?
  • 3 more comments
  • apeed Jul 31, 2008
    Can someone please describe to me how to get to the fuse? Do I unscrew the panel where the timer is? Or is it at the back? A pic will really help. Thanks much.
  • e-uchenna Nov 03, 2008
    Everything seems to be intact and in good condition but the motor does not move. When it is turned on, its seems like there is no power coming in so nothing happens.
  • Anonymous Feb 24, 2009
    Same problem, I have power and the timer ticks but the dryer is otherwise non-responsive. I will check the fuse.
  • Anonymous Mar 31, 2009
    I had the same problem. I located what fixin4years referred to. There are 2 white wires going to it, right beside each other. I disconnected power, hooked those 2 together, and plugged it in. I then tried to start it -- yup, worked. bad fuse - confirmed. Quickly unplugged/turned off (fuse is there for a reason!) yay! i almost just ordered a new motor.
  • leo73 Apr 30, 2009
    "Maytag Performa PYE2200AYW - not working" Replaced timer switch after dryer quit working. Now buzzer works but nothing else.
    Problem Solver:
  • 5 Answers
Yes there is a fuse in the dryer. The black circular thing is a high limit thermostat. Beneath it is the thermal fuse. It is smaller (dime size) and is mounted to the right side of the heating element housing. It is alittle tough to see and get at. You must use the original Maytag part kit.It comes with a new high limit therm. and fuse.
Posted on Oct 26, 2007
Maytag performa dryer stopped in mid cycle
If loose terminal cable connection & Motor Capacitor had been check, you have mechanical problem to investigate..
Jun 08, 2014 | Maytag Dryers
Maytag Performa PYE2200AYW drum turns until I put clothes in it, then it slows and stops.
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to
May 29, 2012 | Maytag Dryers
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I...
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Oct 14, 2010 | Maytag Dryers
My dryer stopped mid drying cycle. The breaker in
Your dryer has an overtemp safety. Called a high limit, it has 2 wires connected to it, and usually is held in place by 1 screw. There will be a couple of them, the one closest to the element will be the bad one. It looks like a suppository, you'll see if you open up the unit yourself. DISCONNECT ALL POWER BEFORE ATTEMPTING ANY ELECTRICAL REPAIRS!!!!!!!!!!
Apr 11, 2010 | Maytag Performa PAV2200
Maytag performa dryer quit working
Check your breaker first and then the wiring. Check power coming from the timer next. With a load and resistance that you had, you could have tripped one of the breakers.Since you have bypassed the thermal fuse, it probably is the timer switch.
Jan 26, 2009 | Maytag PYE2300AY Electric Dryer
Stopped mid-cycle
I have the same problem.  Model: LAT2300AAE Serial: 30220055ZM
Maytag Performa - does anyone have any advise or should I just call the Maytag man?
Jun 05, 2008 | Maytag Performa PAV2200
Washing Machines Logo
1,258 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
