Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
Need help to correctly operate the computer and the fax machine on the same telephone line.
How can i use a brother fax,connected to the same telephone line,as my computer?
    Scholar:
  • 102 Answers
Here is the link which tell us how it works click here
Here is the manual about the brother fax click here
Here is a video about the brother fax click here
Thanks,
Appereciate to rate as "FixYa"
Posted on May 23, 2009
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
Our fax machine keeps saying "busy/no signal" even when we know the machine we're trying to send to isn't busy. Please give us some suggestions as to how to correct this problem. Brother...
Verify the connectivity (phone line) first by pluging a working telephone in the wall jack, than test the cable from the wall jack to the fax, you could install a Y to plug a working telephone with the fax on the same line to spy on what is happening when the fax is engaging a connection.
Hope this helps!
Jan 05, 2011 | Brother Office Equipment & Supplies
Help connecting brother fax machine
1. Connect the handset.
Connect the curled handset cord to the bottom of the handset and to the left side of the machine.
2. Connect the power cord.
3. Connect the telephone line.
Connect one end of the telephone line cord to the jack labeled LINE on the left side of the machine. Connect the other end to a modular wall jack.
WARNING
 This machine must be grounded using a three-prong plug.
 Since the machine is grounded through the power outlet, you can protect yourself from potentially hazardous electrical conditions on the telephone line by keeping the power to your machine on when you connect it to a telephone line. When you want to move your machine, protect yourself by disconnecting the telephone line first, and then the power cord.
 Lightning and power surges can damage this product! We recommend that you use a quality surge protection device on the AC power line as well as on the telephone line, or unplug the lines during a lightning storm.
Dec 30, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I need help connecting my fax machine
WARNING
power cord.
1 Connect the handset.
machine.
2 Connect the power cord.
3 Connect the telephone line.
Dec 29, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Am trying to send a fax on brother 575. I placed the paper face down -- dialed the telephone number and pressed fax start. The receive messages comes up on my machine and the fax does not go...
My first assumption would be, since this appears to be a new fax machine for you, to ensure that the telephone line is plugged into the correct port on the fax machine. There are usually two ports, a telephone port and a line port, you want the telephone line to be plugged into the "line" port.
Let me know.
-David.
Nov 05, 2010 | Brother Office Equipment & Supplies
What does comm error 20 01 mean on my brother 2820 mean? how do I fix it?
This means that your Brother machine experienced a communications error when sending or receiving a FAX. This is generally caused by either interference on the line, phone line connection or another device on the line.
Try resending the documents and see if the message no longer appears.
If the message still appears, there may be a problem with the way the Brother machine is connected or you may have a bad telephone line. Disconnect any other equipment on the telephone line, i.e. answering machine, modem, extra telephones, switching devices, adapters, etc. Make sure the telephone line is connected directly from the jack (socket) on the Brother machine labeled "Line" to the telephone wall jack (socket).
Try resending again. If the transmission is successful, the problem was created by the connection of the Brother machine and the other devices on the line. Reconnect the other pieces of equipment one at a time to see which is causing the problem. If the error continues to appear on the report, try connecting the Brother machine to a different telephone line or have the line checked by the telephone company.
Nov 03, 2010 | Brother IntelliFax-2820 Laser Fax
How do I receive faxes with the 240c
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | Brother Multi-Function Center MFC-240C...
My brother mfc-490cw I can't send or recieve faxes.
According to the User's Manual for the Brother MFC-490CW:
  • Poor Line Connection indicates an issue with your telephone line (Page 136). If you are sharing the fax line with any splitters or computers, try connecting the MFC-490CW directly to the phone jack and send a fax. If you are still getting a Poor Line Connection error message, call the telephone company and have a repair technician check your telephone line.
  • Out of Memory error message means the machine's memory is full (Page 138).
    Try pressing Stop/Exit and wait until all current operations finish and try again.
    Try clearing the data in memory. To gain extra memory space. turn off Memory Receive (See Page 48).
    Try printing the faxes that are in memory (See Page 49).
  • System Busy error message wasn't in the manual, but I suspect it means there's a current operation in progress and the machine needs time to finish before moving on to another job. Just wait for the current job to finish, then try again.
May 05, 2010 | Brother MFC 490cw Color Inkjet...
On my MFC-240C I can no longer receive faxes. We
Ensure that the new telephone is plug correctly into the fax machine the. Phone line belong in the "line" socket. Telephone/answering machine belong in the phone socket. Does the telephoe answering machine work ok without the fax. does fax work with out answering machine
Aug 12, 2009 | Brother Office Equipment & Supplies
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
102 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
