Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Honda IZY engine hunts. I mean the speed pulses rhythmically!
The engine starts easily, but the governor pulses the revs continuously whether it is hot or cold. I am using fresh petrol; I have changed the spark plug. All the linkages are clean and move freely. I have taken the carb off and looked inside. It is very clean, with no deposits. The main jet is clear, and I have **** the bypass jets, though I can't see how to check them otherwise. If I hold the governor lever still, the speed is fairly constant, though it does sound a bit rough. Any ideas would be welcome please!
  • 154 Answers
Sounds like air leaking into the intake.replace the gasket that is in between the carb and the block
Posted on Jun 13, 2009
My Honda gx340 is revving high all the time Can some one tell me y thank you
should be an internal govenor on a plant unit like that
there is a thicker than normal metal rod running off the carby to the motor and that is where you adjust the govenor
cant find good instruction how that governor is adjusted ..if adjusted the wrong way it will rev out may even throw a piston
then check carby idle adjustment
should hunt (rev up and down only slightly )as load changes
you tube
11hp Honda GX340 cold start
https://www.youtube.com/watch?v=i3_v68__X5o
Honda GX340 HGI Partsf21c43c2-def4-46c5-9224-ed46701c0c01.jpghonda-gx340-revving-high-all-time-some-qkhmqzcwln4tohiil4ndbnz4-2-2.jpg
Jun 22, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Why does my generator pulsate while running, what's wrong with it?
This action is called governor hunting which generally means the carburetor needs resetting ,a complete internal cleaning or a rebuild
then adjust the high speed and low speed settings by the adjusting screws on the governor spring system (manual may be required for these settings)
Jun 23, 2014 | Honda 3000 Watt Portable Generator
I replaced the governor diaphragm in my 2h in my hj47 1984 ute and now the engine is hunting at idle between 650 and 860 rpm, it doesn't matter if it is cold or warm. Engine doesn't hunt at hi
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 11, 2012 | Cars & Trucks
Idle problem
There is an arm that runs from the governor arm to the carb. There should be a long spring on this to even out the revs. If that has come off it can cause similar problems. If you have checked/reset the governor arm on the pinion that comes out of the crank housing and the spring is in place I would think the only other problem is the actuator that operates the governor arm pinion internally. It is a strip down job to check it, but there is a (plastic?) cog that runs of a gear on the side of the crank shaft. This has a weighted pusher that moves with engine speed to move the governor arm. I have seen a couple of engines where there is wear and the weights have popped over the 'top hat' pusher stopping it moving freely and causing full revs. If you're not confident in stripping the crank casing down (you can leave the piston and crank in place to check the governor mechanism) then you should definately take it to a dealer or experienced technician.http://www.honda-engines-eu.com/engines/PartSelection.jsp?model=GX390K1&type=BJ&npl=10ZF601%20&lang=EN
Position 9 is the governor assembly.
Jan 11, 2012 | Garden
My Honda 13.5hp engine has started surging. It seemed to occur after the air filter fell off during mowing for a few seconds. I have tried cleaning the carburator but it still surges. Anything else I can...
Hi sndlys,
When the engine surges (we call it hunting) like that it usually means, the carburetor or the governor need adjustment. You have cleaned the carb. but did you clean or replace the air filter, and did you try to adjust the carb? Since it was running good before I doubt it is the governor. Try to adjust the high speed mixture screw by 1/8 turn at a time and waiting a few seconds to let that adjustment work it's way in the carb. Start by turning the screw out (counterclockwise) a few times. If nothing happens or gets worse turn the screw in (clockwise) a few times, but do not go less than 1 turn out from a lightly seated position. (turned clockwise until lightly seated so no damage is done to the seat or the needle screw) to prevent running in too lean a mixture to prevent overheating and possible engine damage. You could try the low (idle) speed mixture screw adjust a bit, but make sure you remember the position you started from whenever you any adjustment at all. I think if the carburetor is clean and the air filter is clean, also that there is a good fuel flow to the carb. you should be OK. I hope this helps out a bit.Get back to me if you need help. All the best and good luck. Denis.
Mar 02, 2011 | Honda Garden
Hello i have a Honda izy self propelled it is 3
sounds like your petrol filler cap hole is blocked , try and drill a hole in the cap or loosen the cap slightly , and change the spark plug , the izy can go through plugs regularly, you could try a good wire brushing and set the gap
good luck
Jul 10, 2010 | Garden
04 PT cruiser will not rev above 2500rpm
Yes there is a governor which limits the rpm to 2500 rpm. It ha been limited because beyond this rev, the engine gets overheated and if kept running it that condition would slowly but surely damage the engine badly. Once you have reached the limit naturally your cruise control will stop working since its supposed to maintain that speed, which is not allowed by the governor. This governor can be removed but then you will have to risk damaging your engine fatally........................sodeep
Jun 29, 2009 | 2002 Chrysler 300M
Just adjust the idle speed control/Fuel air screw located pointing downward on the bowl of the carb,Just start the engine,idle up high and turn the screw until it levels out and runs smooth.
May 31, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Honda snowblower engine hunting
Sounds like you are hitting the governor. Watch the arms at the carb when you move it to full throttle. The arm should hit a screw. Turn this screw clockwise, until the reving stops.
Dec 08, 2008 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
880 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
