Question about Acer AL1916W 19" LCD Monitor
Selection of a good monitor for a graphic designer
The colour output of the monitor and the natural colour are not match. So, I want to know, how can i choose a good LCD monitor in the current market?
HP Pavilion f1703
Posted on May 24, 2009
Why is the image generated by my ATI Radeo X500 yellowish?
It may be a faulty card or may just need setting up for your monitor. Try at least another monitor to see if it's the same. I can't gauge how far out it is without seeing it. Make sure your video settings for colour temperature match your monitor, if you monitor is set to a lower temp than the output of your card it will look yellowish.
May 12, 2014 | ATI Computers & Internet
I follow all instruction on my M-audio/m-track 2 channel but can't get the audio out to my monitors. can some tell me what I'm doing wrong?
Control panel>Sound & Audio Devices>Audio>select your desired default output . . .
Hope this will explain . .
Sep 01, 2013 | Computers & Internet
Elekta lcd tv
Some monitors are real pain... I know..
You can try different colour software managers out there. I'm using one myself. Here's one recommendation.
I hope it helps.
May 21, 2013 | Computers & Internet
Screen colour changing
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
Mar 31, 2012 | Acer P195HQB5 18 inch LCD Monitor
Composite connection on Gateway Desktop
They are Video and Audio for connecting device together
  • Yellow = Video
  • White = Audio - left channel
  • Red = Audio - right channel
the connectors on a Desktop PC from the graphics card will be an OUTPUT-possibly labelled TV output, so what ever is displayed on your monitor can also be sent to a TV or recorder etc The connectors on the Xbox are also OUTPUT and designed for connection to a device which has the same connection but for INPUT
Your monitor may have composite inputs and allow you to switch to those Some TVs will have those connections as inputs and you would select one of the AV options to see the signal, often a separate button to choose AV input /HDMI / PC etc Some DVD and Video also have these as an INPUT as video cameras often have that type of connection - to record the signal
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | Gateway GT5453E Refurbished AMD Desktop...
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Color matching
If this is a print problem and not just a screen issue, here's what I suggest.
In Illustrator, double click the colour swatch for the Pantone Book colour you are using and obtain the CMYK values.
In Quark, instead of using the same Pantone Book colour, create a new Process colour with the same CMYK values as the Illustrator swatch.
May 20, 2009 | QuarkXPress
Prints light purple instead of grey
I think your Black Cartridge is Empty. Check it and replace it with the new one.
Your Printer is trying to produce Black Colour from your Colour Cartridge with a mix of Cyan, Magenta and Yellow.
Apr 23, 2009 | Canon PIXMA MX850 Multifunction Printer
I have a Dell Dimensions 8300 with a GeForce FX5200 graphics card (version C.14.10.4502).It has D-Sub and DV1 outputs. The monitor is connected to the D-Sub output. However anything connected to the DV1...
Hey,
in windows, right click on your desktop, select properties, then settings and then click on the 2nd monitor, make sure the 2nd monitor is attached to the dvi, when the computer was turned on. so the 2nd monitor will appear in the settings.
this will give image from the dvi output. to get objects to the 2nd monitor drag them out of a corner of the first screen. debending on what side the monitor is at.
Let me know if you need anything elsed.
Thanks,
Ekse
Feb 18, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Acer AL1916W 19" LCD Monitor Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
