Question about Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor
SCREEN turning to black and wont stop?
Hi der? got problem on my cpu when loading xp its oky after loading with the screen on my deskstop it start getting block and the screen become dark then it start popping then it will appear again dunno wat's the problem is it the video memmoy sir or the video card because i install many software and games i think i must have reach my video capacity that's why this happen nid expert opinion on this? my mother board is asusPSPVM pentium4 processor intel p4 1.7ghz!:))
    Scholar:
  • 103 Answers
*Before installing games, check about the system requirement for that particular game. If your system suits then install that game.
*Check the monitor by unistalling some games for one or two days, if this is the problem then put hiyh capacity VGA card to your system.
*Also check the ram.
Thanks,
Apperecaite to rate as "FixYa"
Posted on May 23, 2009
  • 46 Answers
How old is your monitor? If it's an LCD type with 5 to 9 years of age then it may have burned out lighting inside of it. You would just replace the monitor. Check the back of the monitor for the date. If 2004 or earlier then you need a new monitor. You did say the video comes up to desktop, so it's not the video card, and the pc booted up so it's not the cpu either. I've had this problem too.
Ga-g41m-es2l xp install problem
do you have enough memory (RAM) ? .freezes means to little memory.
Jun 09, 2013 | Computers & Internet
My window xp has no monitor
Is the screen black from the moment you turn your PC on? Or do you see the BIOS splash screen and Windows loading, but when Windows starts it goes black?
Jan 21, 2013 | Computers & Internet
PROBLEM WITH VIA MOTHERBOARD
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck and don't forget to leave a rating.
Thanks
Mark
Dec 06, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
MY SCREEN KEEP popping to black?it annoys me?
so is your screen like fading to black and back to bright when u do something? If it fading in and out try adjusting the monitor settings on the monitor itself. Whats happening is your monitor is trying to save energy so it dims. The setting is Luminance on most monitors
And by the way u cant reach a video capacity cause the memory dumps the info when it needs space to process more video.
May 23, 2009 | Intel Motherboard
Black screen
Ensure that the power button is pressed and the monitor is plugged in correctly. If ok, then the installation was stopped while installing your video drivers. If possible use another monitor to re-load the xp operating system until completed. Once the video monitor drivers are loaded the monitor will work again. Let me know if you have any questions.
Don't forget to rate this solution before you log off.
Jan 26, 2009 | Compaq Presario S4020WM PC Desktop
My computer wont go to windows xp when started up and it doesnt even go to any type start up screen
hi gllwymiller;
1.check all your connections
2.check monitor and cpu power
3.when you power on your cpu, do you actually hear the fan turning or see your power led light up?
4. what OS are you using?
5. Feel the rear fan or your CPU, is it blowing out air?
get back to me :)
Jul 01, 2008 | Gateway Computers & Internet
Black screen at power on
I had the same problem. I pull of battery and then immediately reattached and ta-daaaa! Windows came right up!
Hope this helps!
gg
Jun 23, 2008 | Samsung Q1 Tablet PC
Windows wont load
is your computer set to boot from cd?
Jun 01, 2008 | Computers & Internet
Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor Logo
62 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
