Question about Poulan Weedeater/Electric Trimmer 4.1 Amp
My weedeater edger over heats and freezes up. it gets very hot, smokes around the spark plug, the spark plug is coverd with soot and it won't start again
  • 11,896 Answers
Are you using mixed gas? The gas needs to be mixed 50:1
You will have to use 2 cycle oil. If you are using mixed gas, than you can buy a cooler spark plug.
Sounds like the spark plug is not properly gapped.
Posted on May 23, 2009
I got a 2 cyl featherlight weedeater I put a new
You need to be sure you're getting fuel and spark before you do anything else.
Sep 09, 2014 | Garden
Ford laser 99 no power
Hi there.
well when you throttle up to about 2000rpm do you get blue smoke coming out the exhaust.When driving on flat road will it power up as normal with out missing or getting hot.
what colour was the old spark plugs were they black or light brown.
When you start engine and run for 3 minutes then let it idle and remove oil filler cap do you get smoke coming out.
Number 1 if yes then engine is lacking power due to piston rings worn answer rebuild engine.
Number2 spark plugs brown [good] if black soot as num1.
Number 3 if you get black smoke or blue ,then the engine is lacking compression could be your problem as num1
OTHER WISE GET YOUR TIMING CHECKED AND SET TO BOOK.
May 23, 2014 | 1998 Ford Laser
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
Weedeater PE550 will not stay on. Prior to placing this unit in long-term storage, the unit worked. Since pulling it out for this season, it would not start. I replaced the fuel lines and primer bulb. ...
Is the smoke coming from the spark plug hole or just near it?
There are three things that you need for it to work.
Fuel, air and spark.
If you are missing any one of those things, or if one isn't optimal, it wont work well if at all.
You say spraying carb cleaner into the chamber lets it start, but after a minute it dies?
That tells me you are getting a spark.
Have you taken the carburetor out and cleaned it thoroughly with carb cleaner?
Often when fuel sits around inside a carburetor it can build up gunk and make it not function properly. I recommend removing the carburetor and taking it completely apart, cleaning everything with carb cleaner and putting it back together. It sounds difficult, but I promise it is not, just take pictures to help you remember how everything goes together if you want.
Also while you are at it either clean or replace the the air filter, that should help as well. If its a foam filter you can clean it with gas, if its paper, just buy a new one.
Jun 07, 2011 | Poulan Pe550 Gas Edger
Weedeater gas edger won't start!!!!!!!!!
yes, there is a spark module, but it's highly unlikely that two would have a bad module - more than likely, it is your gas mix. it must be fresh for the engine to run. the gas we have today will go bad in about a month and a half. if you happen to live in an area that has E85, forget it. small engines will not run very long, if at all on this junk. in some areas, you can get gas without alcohol, but it can only be used for lawn & garden equipment. it's expensive, but your engines will run
Sep 20, 2009 | Craftsman 25cc Gas Line Trimmer
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Stihl FS85 Weedeater
I suspect carb. trouble. Is the compression OK? Look at the spark plug after trying to start it. If it is wet, you are getting too much fuel. The white smoke indicates that. You may need to overhaul the carb.
Go on the Stihl site and customer service for information.
Sep 17, 2008 | Garden
Poulan Weedeater/Electric Trimmer 4.1 Amp Logo
474 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
