Question about LG Vu CU920 Cellular Phone
Locking the phone with a code
I want to set a lock where only i know the code so noone can get into my messages without knowing the code
  • 108 Answers
ENTER THE CODE AND OPEN AND READ UR MESSAGE AND CLOSE UR PHONE AND GO AGIAN IN TO THE MESSAGES AND IF IT ASKS THE CODE GO BACK AND GO TO SETTING AND OPEN LOCKS FLODER AND CLOSE ALL CODE AND TRY IT OK RATE ME
Posted on May 24, 2009
What is the Pin code for samsung GT-S6010
How To Check Which Lock Needs Unlocking On Your Samsung Phone:
  1. Turn on your phone without a sim inserted
  2. Type * # 7 4 6 5 6 2 5 # this will display which lock is active
    (An easier way to remember this is * # S I M L O C K # )
  3. Doing this will display a screen similar to the example below, ON means that particular lock is locked, OFF means it's not locked :
    Network Lock [ON]
    Network Subset Lock [OFF]
    SP Lock [ON]
    CP Lock [OFF]
If only the Network lock is displayed saying ON then you will only need to use the NCK code with the instructions below.
If you see the Subset lock value as ON then you will need the SCK code and if you see the SP lock value as ON you will need the SPCK code.
How to enter specific unlock codes
  • Once you know which lock(s) is active, you can now enter the specific code for it, as follows:
    If your phone says the NET lock is ON then you need to do this without a SIM inserted: # 7 4 6 5 6 2 5 * 6 3 8 * NCKCODE #
    If your phone says the SP lock is ON then you need to do this without a SIM inserted: # 7 4 6 5 6 2 5 * 7 7 * SPCKCODE #
    If your phone says the Subset lock is ON then you need to do this without a SIM inserted: # 7 4 6 5 6 2 5 * 7 8 2 * SCKCODE #
Once all locks are OFF, your phone is unlocked.
Jun 01, 2014 | Samsung Star GT-S5233 Cell Phone
I dont know how to get a password on my nokia x6 - like when i go to my messages or images ect.. - i just want a password thing so only i can get in, anybody know how...? thanks x
Select Menu > Settings and Phone > Phone mgmt. > Security > Phone and SIM card. > Lock Code
The lock code is used to unlock the device. To avoid unauthorised use of your device, change the lock code. The preset code is 12345. The new code can be 4-255 characters long. Alphanumeric characters and both uppercase and lowercase characters can be used. The device notifies you if the lock code is not properly formatted.
Mar 29, 2011 | Nokia X6 16GB Cell Phone
Putting a lock code on an e71 to unlock phone
It is possible to put code on E71, You go to settings then security, you will enable the keypad security code and enable your phone code also. With these nobody can access your phone without asking for security code. Take note Phone, sim and keypad pin code must be enable. Thanks
May 13, 2010 | Nokia E71 Smartphone
Password setting
If you don't know the password, u need to reset ur phone
(will delete everything on the phone memory) make sure to back up ur files the reset the phone using the codes.
**phone should be On without the simcard.
**go to the dial pad then press *2767*3855#
**phone will restart & the default codes on the application lock is either the last 4 digits of ur celphone number or 0000
that will work 100%...
Dec 16, 2009 | Samsung SGH-A877 Impression Cell Phone
I have a 13 year old daughter, andhave taken her phone away from her. She locked the phone, and I need to see what is on it. How can I unlock the phone? It is a LG VX8300. Thanks
Sometimes, the last four digits of the phone number will not work as the unlock code, especially if your daughter has changed the code. Even if the phone is locked, dial *228, then press 1 when prompted by the automated system. When it tells you: "Your phone has been programmed successfully", press "Done" or "OK". Once the phone has powered off, then back on, (it will do this automatically) the lock code for the phone will be changed to the last four digits of the phone number. For example, if the phone number is (315) 123-0101, your lock code, after following the above instructions, will now be "0101". Also, you do NOT need to know the lock code that your daughter had for this to work. After the phone has powered back on automatically, you will be able to use the phone normally. *228 does not delete text messages, contacts, etc, but it WILL give you access to a phone which has been locked, without requiring you to know the code that she has set.
Jun 24, 2009 | LG VX8300 Cellular Phone
Samsung rant user lock
try # # 3282 #, opt 4, opt 1 and scroll down until you see lock code. let me know if this worked
Mar 31, 2009 | Cell Phones
How will i have a code on my n70?
well, you can choose to use a 'PIN code' or a 'Lock code' or 'Memory card lock'
1. PIN code actually locks up your SIM card, so anywhere you put your SIM card, the message on your SIM card will not be read by anybody without knowing your password. It'll ask you password each time you switch on your phone, but after switched on, it'll not be locked anymore, so anyone can read your phone after switched on.
2.while Lock code, locks your mobile phone like 'keypad lock', the different is, instead of just pressing , left softkey and * button, you need to put password on it (it lock after certain idle time - or you can choose to lock it anytime you want by pressing the on-off switch one time (don;t press too long) and choose the belowest which said lock phone ). this type of lock is commonly used.
3.Memory card lock, locks any application which access your memory card, such as images, text, songs, data that is stored on your memory card. but this type of lock, often bring troubles when the memory card get corrupted. so I suggest number 2 type of lock (lock code)
WARNING!!! all password should be remembered, as if you forgot those password, no body can help you unless technician.. see those articles which people post when they forget their password, so you know the risk and the consequences. But they're actually safe as long as you remember ^^
Good luck, all the best!!
Nov 16, 2008 | Nokia N70 Cellular Phone
LG Vu CU920 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
