Home | Sharp | AL-1642CS Copier | Will not copy
Sharp AL-1642CS Copier
Problem for Sharp AL-1642CS Copier
Will not copy
By togarrugs on May 23, 2009
Prints fine off computer but makes a shrill awful noise when trying to copy and paper comes out blank.
Michelle
Togar Rugs
togarrugs@aol.com
Comments:
May 23, 2009
- thank you so much. This is the first time using this site. You guys are great!!!!!
Best Solution
posted on May 23, 2009
Helpful)
goalie39
Rank: Guru
Rating: 91%, 228 votes
Sounds like a scanner issue, when you make a copy, lift the lid slightly, does the scanner pass by smoothly? if not, it may be obstructed, or it could have a motor problem.
If it an obstruction, you should see it as the scanner moves, turn the machine off then on, this usually causes a scanner pass and reset to home. Look through the glass as it does so to see if it is catching on anything. if it is a foreign object, remove the glass and clean out the optic cavity.
If only one side moves or the scanner is crooked, it has slipped on its cables.
If it just moves in jerky fashion, it could be the motor.
Hope this is of some help.
Ed
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sharp AL-1642CS Copier
Questions and Unsolved Problems for Sharp AL-1642CS Copier
Do you recommend Sharp AL-1642CS Copier?
Answer
Answer
I have a toshiba e-studio 160 photocopier and i need to know the password. The admin in charge of... (More)
Answer
i have fault code C14A3, what does it mean and how do i access service mode on copier docujet 3016F
Answer
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant... (More)
Answer
adf adjustment for sharp copier AL1642cs
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AL-1642CS Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 1487
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
