Question about Delta 10" 3 Hp, 230V, Single Phase, Right Tilt Unisaw® 36 R31
Unisaw Jet Lock rip fence set-up
Unisaw Jet Lock rip fence adjustments
    Problem Solver:
  • 9 Answers
Go online to OWWM.com and download the manual. Don't forget to make a contribution. This will give you the step by step instructions for setting up fence. The jetlock is pretty easy.
Posted on Apr 04, 2010
Difficulty raising and lowering the blade on Delta rockwell10" unisaw 34-450
Ok, basic question...is the lock engaged? It is the small knob at the center of the adjustment wheel. Is it possible the screw has been galled?
Here is the manual- http://content.powermatic.com/manuals/1791227K_man.pdf
May 27, 2014 | Powermatic 1791227K Model 64 10" Artisan...
Table saw blade alignment
Are you referring to the table top or rip fence alignment? The blade itself is not aligned. We adjust the table to parallel with blade and the rip fence should toe away from blade 0.01mm over the length of the rip fence to prevent binding.
Jan 14, 2014 | Delta Saws
Sawblade is not parallel with fence on delta tablesaw
The Rip fence SHOULD toe out aprox 0.010mm over the length of the rip fence to prevent binding. Adjust using the Rip fence to measuring rail. Should be adjusters there but if its an old saw, you may have to adjust the measuring rail where it meets the saw frame.
Jan 06, 2014 | Delta Saws
I have a biesemeyer 52inch fence on my delta unisaw I have had about ten yrs. The fence has always wOrked great. But now the fence will not lock, making using the saw next to impossible PLEASE HELP!!!!!!!
Prob needs the plastic pads that hold the position when locked. should be readily available at any Biesemeyer outlet as they are replaceable.
..or make your own.
Feb 12, 2013 | Delta 78-918B Biesemeyer Fence Table Board
How do i square the table to the fence on a dewalt table saw?
Normally we adjust the rip fence so that it toes out 0.10 mm over the lenghth of the rip fence. Some models have to have the trunion shimmed or the table removed/adjusted to achieve this. The toe out ensures no binding but doesn't effect the measuring. Note. adjusting the trunion is a large job.
Feb 11, 2012 | Dewalt DW744X 10" Portable Table Saw
HAVE OLD MAKITA 2708 TABLE SAW HOW DO I SQUARE THE BLADE
Hi rjames16,
Are you wanting to square the blade to the rip fence, to the miter fence or does the blade show runout?
To square the rip fence to the blade, lay a combination square or engineer's square along the blade with the short leg against the closest end of the fence and even with the near end of the blade. Slide the square along the blade so that the short leg is even with the far end of the blade. Loosen the lock knob and move the far end of the fence until it touches the leg of the square. Tighten the lock knob. Recheck and adjust the fence until it is perfectly square to the blade.
Adjust the miter fence to the blade in a similar fashion except that the short leg of the square will lay against the miter fence. Adjust until the long leg is aligned with the blade. The instructions for these adjustments are in the owner's manual.
You can download a copy at this website: http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=604
Copy and paste this entire address into your browser and a page will open with 2 Adobe documents. One is for the owner's manual, the other for the parts breakdown.
If you have blade runout, remove it from the saw and lay it flat. Check for warping and if warped, replace it.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 30, 2011 | Saws
Rip fence is out of alignment..what do I need to do?
This is the fundamental problem with rip fences on table saws. I don't know what kind of rip fence you have, but most rip fences are adjustable for squareness. However, unless you have a very nice (and expensive) rip fence, they often don't self-align when you move them anyway. If you have the type that clamps at the front and the back of the table, the problem can be overcome by making sure the rip fence is straight before you clamp it in place. The easiest way I have found to do that is to use an adjustable square. Put the front of the rip fence where you want it, then set the adjustable square so that it matches the distance from the miter slot in the table to the fence. Then move the square to the back of the table and move the back of the fence to meet the end of the square. Now clamp it in place and check the front and the back one more time. It's tedious to do this every time you adjust the fence, but you can get a perfectly aligned fence this way. This method assumes that your blade is parallel to your miter slots, which is adjustable too, but you have to get underneath the saw to do that. good luck, Al K
Jan 14, 2011 | Saws
My unisaw fence does not stay in alignment, the back end keeps moving out by an 1/8 in and sometimes more. What is the proper procedure for aligning the fence so it stays aligned.
That fence is one of the easiest to adjust and maintain. Look behind the lock at the white squares that slide along the front of the fence, one missing? Or worn down past the other side? It has a screw on the outside to adjust it in and out. It is a big Allen head. Line the fence up to a saw slot in the table, lock it loosely, adjust the screws so the fence is aligned with the slot, move it and bring it back, it should match up. Make sure it has the nylon pads on there or it wear through the aluminum real fast. Check it out, Hope this helps.
Aug 31, 2010 | Garden
I have a 1979 unisaw and it is burning stock . the arbor is 0.001" off ,I checked with a digital dial indicator. I have not used my fence just cross-cutting with my delta miter gauge. I bought a new freud...
I would use a straight edge, to see if the blade is parallel to the table. Bring the blade up, put the straightedge on it and measure to one of the dado cuts in the table, front and back should be the same. If not, You can loosen up the mounting bolts underneath and tap the whole thing around to square it up. Hope this helps.
Jan 08, 2010 | Delta X5 3Hp Left Titl Unisaw with...
Biesemeyer fence not parallel to blade.
Yes you can adjust the angle of the fence. There are two adjusters at the front of the fence where it meets the fence rail. Adjusting these will pivot the fence either slightly left or slightly right.
There is a basc video on youtube my daughter made to show you how to align yourfence to the saw blade.
Feb 28, 2009 | Delta Machinery 3 HP Left Tilt Unisaw with...
Delta 10" 3 Hp, 230V, Single Phase, Right Tilt Unisaw® 36 R31 Logo
695 people viewed this question
Top Delta Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Delta Measuring Tool and Sensor Expert? Answer questions, earn points and help others
