Question about Onkyo HTR500 Receiver
Blown Fuse, needs fix'n
The fuse on my Onkyo HT-R500 is blown. I need to know how to replace it. The manual says its not user-serviceable, but I doubt thats true, and I'm not paying somebody to fix my 5 year old receiver.
  • 1 more comment
  • Anonymous Nov 21, 2007
    when you turn power in it shuts right of and goes on stand by
  • harley5571 Apr 21, 2009
    I looked at fuse..it seems to be ok..now what?
Regarding the last answe, how do you know if it is slow blow or fast blow?
Posted on Jan 21, 2008
You CAN open the unit (keep in mind that even unpluged there is still voltage runing through the system, so.... dont fry) and you will notice, if the face of the unit is towards you you will see on the left hand side a power supply board, the fuse is on that board, and it is a tube fuse, 125V 8A. Most stores do not carry the 125V version anymore, but will carry a 250V. This is okay to use where the voltage is not the main purpose of the fuse.
Posted on Dec 27, 2007
Where can i find the fuse?
What Can Break in a Massage Chair? - Elite Massage Chairs
https://www.elitemassagechairs.com/what-can-break-in-a-massage-chair/
So believe it or not, the most common problems in a massage chair - about 90% of ...but it's not always easy depending on the design of the chair to find the fuse that ...This is the electric motor that moves the footrest up and down in a smooth ...
power outlets fuse location Electric Massaging Chairs ...
www.fixya.com > Forum > Tags > power outlets fuse location
Electric Massaging Chairs power outlets fuse location questions and answers. ... I need to find the massaging mechanism unit for my ijoy 250 massage chair Product ...Where can I purchase a plug in outlet chord (power chord) for the osim ...
electrical fuse blown Electric Massaging Chairs Questions ...
www.fixya.com > Forum > Tags > electrical fuse blown
Electric Massaging Chairs electrical fuse blown questions and answers. ... In short does anyone know where I can get a circuit board for this chair? ... I need to find the massaging mechanism unit for my ijoy 250 massage chair Product manual: ...
radio ht Electric Massaging Chairs Questions & Answers ...
www.fixya.com > Forum > Tags > radio ht
Electric Massaging Chairs radio ht questions and answers. Ask your radio ht electric massaging chair questions. Get free ... Do you know where I can find fuses?
Amazon.com: Electric Full Body Shiatsu Massage Chair ...
Dec 14, 2015 | Furniture
How to setup
http://www.manualslib.com/manual/302221/Onkyo-Ht-R500.html
Jan 10, 2015 | Onkyo Ht-r500 5.1 Channels Receiver A/v...
Onkyo AV Receiver HT-R500 No power whatsoever, no illumination of any display options and no activation clicks upon pressing the power button! We inspected the receiver via dust cover removal and found no...
If that is true the power transformer is probably open at the primary, the secondary voltages feed the receiver and power various parts. I suggest getting it checked, my worry is the power transformer may not be available from the parts manufacture.
Mar 28, 2012 | Onkyo Audio Players & Recorders
Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Apr 21, 2009 | Onkyo HTR500 Receiver
I have a onkyo HT-R500 receiver and it keeps blowing fuses.
A receiver that recent usually has a detect circuit that keeps the outputs off until speakers are connected . So, if it bows fuses right away , it's really a power supply issue.
Probably the AC rectifier bridge.
Tech service only.
Dec 27, 2008 | Onkyo HTR500 Receiver
Onkyo ht-r500
I found the manual sometime back...try 3Xdouble-u dot eserviceinfo dot com
Aug 06, 2008 | Onkyo HTR500 Receiver
Ht-r500 onkyo
When a receiver does this, it is know as the "protect mode". This keeps the receiver from causing more damage to the components in it, by shutting it off when it detects an abnormal amount of voltage or current.
If you had to replace the fuses, it is most likely that you have a blown channel in the receiver.
You put 8 amp fuses in, so I hope that the fuses that blew were 8 amps as well. If you put fuses in that are higher rated in amps than the ones that blew, you will most likely cause more damage to the unit than need be. If the fuses keep blowing, please stop putting new fuses in again until the unit is repaired. Every time a fuse blows, it is because of too much current is going thru the unit. Having too much current is a very bad thing for electronics, it causes components to short out and sometimes even catch fire if the fuse is higher rated than it is supposed to be.
To find out just what parts will need to be replaced, you need a multimeter and then you will need soldering tools to remove the bad parts and put the new ones in.
When an amplifier channel gets blown, there are normally around 5 to 10 parts that will need to be replaced. If you do not replace every single bad part in the channel that has blown, you will most times blow up all the new parts that you just put in.
If you have no experience with electronics, you really should take it in to a service center for repair. If you are willing to try it yourself, let me know and I will guide you thru the troubleshooting steps to help you identify all the faulty components.
Onkyo is very well made equipment and is worth getting fixed.
A blown channel can normally be repaired for around $100 to $150, just depending on the shops rates and the extent of the damage.
Let me know if you need more help.
Dave
Jul 26, 2008 | Onkyo HTR500 Receiver
Onkyo HT-R500
Unit has circuitry problems, take in for service
Mar 14, 2008 | Onkyo HTR500 Receiver
Wireing
Consult HT-R500 operations manual for hook up
Feb 08, 2008 | Onkyo HTR500 Receiver
Onkyo HTR500 Receiver Logo
630 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
