Question about Kenmore Dryers
Kenmore Series 80 Model 110 Dryer
Everything is working except for a load banging noise....it spends....it heats.....are there some kind of bearings or something that are causing this problem......is this a death sentance......
    Genius:
  • 1,122 Answers
If you take the top off you will see the back of the drum rides on rollers and the front of the drum rides on a felt pad,check both for wear,if you have a top mount lint filter remove the 2 screws pull the top toward you and up and your in-mike
Posted on May 24, 2009
Kenmore 80 series dryer banging
Yes you need to replace the tumbler guiding wheels .should do that soon so you don't ruin the motor and belt
May 03, 2014 | Dryers
I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Feb 02, 2010 | Kenmore 64742 Electric Dryer
I have a Kenmore 80 series dryer(118.72812101).
You may have something inside the workings of the dryer which has shorted out the heater coil. this could be the source of the noise as well. you need to remove the cabinet to access this, yet be careful as the drum will fall out on you in process. You can get a new coil from an appliance part store in your area. Take the dryer apart before buying this tho, so you don't waste your money on the off chance that this isn't the trouble. you will need make model and serial number from unit so they can match up the proper coil for you. Make note of how the belt is placed and routed for proper replacement when reassembling. Also make note of 'drum rollers' condition, as this could be some of the noise also.
Best to you, hope it works out
Joe
Aug 26, 2009 | Kenmore Dryers
Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
May 26, 2009 | Washing Machines
My Kenmore 80 series dryer is shutting down
Please post the complete model number of the appliance.
Possible problems are -
1) Motor bearings are failing (lack of lubrication).
2) Idler roller is failing (lack of lubrication)
3) Blower bearings are failing (lack of lubrication)
Dec 29, 2008 | Kenmore 659 Electric Dryer
Kenmore 80 Series Model #110.74842400 Series MR5112733
There's a few things on this dryer that can stop it
from heating. 1st thing your going to need is an ohm meter, your testing simply for continuity. The main items that cause no heat at all on this gas dryer is the igniter on the gas valve, the thermal fuse located on the blower wheel housing the thermal cut out located on the burner box or the flame sensor on the burner funnel and lastly the coils on the gas valve. the sequence is from most too least common. Of course unplug it and shut the gas off.
Jul 30, 2008 | Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
