Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
HOW DO YOU BY PASS THE FLAMABLE VAPOR VALVE ON A HOT WATER HEATER
  • Ned C Cook
    Ned C Cook May 11, 2010
    if you need to bypass it, it's no good. Have it professionally repaired. Please.
  • HANK MCNEIL May 11, 2010
    If you do you violate federal and state laws, void your warrenty, and would not be covered by your homeowners insurance if it can be shown that contributed in any way to a fire. DON'T!
  • 44 Answers
You buy a new water heater AND have a QUALIFIED person from your gas supply company or a qualified plumber install it.
You bypass that valve and you're just asking to blow up yourself, your family, and possibly any nearby neighbors. They'll be picking up pieces of your house a quarter mile away.
As the other posters said, too, any means of bypassing this valve is in violation of all kinds of local, state, and federal laws, voids your warranty, and will definitely be found by the fire marshal when they try to determine what caused your house to suddenly explode, thereby ruining your chances at getting a settlement from your insurance company. They may even classify it as arson. All points considered, and no offense intended, it would be downright stupid given the safety implications.
Go to YouTube and search "propane explosion" or "natural gas explosion".
Posted on May 24, 2009
Water heater is leaking I need to drain it how do. Do that
Turn Off Power or gas to heater, shut off incoming water supply, open the hot water side of a nearby faucet, attach hose to bottom drain valve, open drain valve, drain tank. Opening faucet should stop it from becoming vapor locked.
Oct 02, 2017 | Water Water Heaters
Reset lock out due to fvd
You can reset some models.... depending on gas control valve and FVIR design.
Some newer models you replace the sensor located on outside of tank.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-flammable-vapor-sensor-works-Therm-O-Disc-25VS.pdf
Gene
Jun 04, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water meter is ticking away. No sign of water or
If you have a gas hot water heater, water may be dripping onto the baffle plate at the bottom and vaporizing whenever the burner fires. There would be no evidence of water under the heater in this case. Yes, I speak from experience. Also check exterior sill cocks for leakage as one might be open just a tiny bit. If you wait for freezing weather, a leaky sill cock will grow a "beard" of ice.
Oct 30, 2013 | Rheem Water Heaters
Hot water heater womt light, flammable vapor sensor code
Most likely: Combustion chamber got too hot because air intake is clogged with dust, causing less air to flow upward through vent pipe ... the slowed flow of air caused combustion chamber to overheat.
What brand and model water heater?
Look at label on side of unit and add comment.
Otherwise call service tech to repair/ replace water heater and clean arrestor screen (air intake) and replace or reset parts as needed, depending on model number and brand water heater.
AO Smith, Bradford white, and Rheem are main manufacturers.
Each has slightly different repair protocol, and each gas control valve can also be different. So more information is needed.
Identify gas control valve:
Rheem TRD/ FVIR glass vial
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
How to remove combustion parts to inspect for Rheem glass vial and clean arrestor screen located under combustion chamber:
http://waterheatertimer.org/How-to-replace-thermocouple.html
Sep 30, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Detecting gas and won't light
Open following link for troubleshoot error codes showing 7 flashes on Honeywell gas control valve is system lockout due to flammable vapor:
http://waterheatertimer.org/pdf/Honeywell-gas-control_error-Damper-series.pdf
The FV system in Rheem can be tripped by presence of flammable vapors such as gasoline or paint fumes etc, or it can be tripped if water heater was dropped, or mis-manufactured, or if gas control valve is defective, or if water heater is not getting adequate fresh air, or there is inadequate venting of combustion by-product.
When combustion chamber overheats, then glass vial breaks and damper shuts off air supply to water heater and it will not light.
Open following link for possible help fixing the problem:
Jun 13, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water coming out of tap but we do have cold water out of cold water tap...any suggestions??
Check your by-pass valve(s) at back of water heater. Water goes in cold to bottom fitting, and out hot at top fitting, so those 2 valves ( if any) need to be open, anything in between needs to be closed. There are a few different by-pass set-ups, so if that doesn't explain it, get back to me with a description of your valve set-up and I'll guide you through it. If valve(s) are all in proper position and still no flow through hot line, I'd suspect faulty check valve in between hot line connection and tank.
Aug 07, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
No water pressure on hot water, when i by pas
How many valves on by-pass, or what style by-pass have you got on there? Remember water has to go in bottom (cold) and then out top (hot) . No valve in between should be open. Valves going direct in to cold, and out hot need to be open.
Apr 25, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
207 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
