Question about Dishwashers
Water left in bottom of dishwasher after cleaning
There is water left in the bottom of the dishwasher after it has run a cycle. I have tried to turn it back on and have it drain and it doesn't fix the problem. I have also tried just to run a rinse cycle and it still leaves water in the bottom. It is less than 2 yrs old.
I cleaned the pipe, but most importantly, to make sure water flows freely through the Y-junction where two hoses exchange water, I cut a piece of plastic from the mouth of washer hose, the problem got solved.
Posted on Dec 01, 2012
  • 11,896 Answers
I suggest checking the drain and screen. There is most likely a little clog in there. If there is even the slightest amount of clog, the washer will not finish the drain cycle.
Posted on May 23, 2009
4 Suggested Answers
SOURCE: Water didn't drain, left in bottom of washer tub
I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
Posted on Aug 05, 2009
caroldon
  • 17129 Answers
SOURCE: The water is not draining
Possible that the drain pump /drain valve is not working . it can be struck or it could have failed. Best is to check the voltage during the program . If voltage is present then pump is faulty but if voltage is not present then the controller board is not working ,possible failure in the board.
check this link for some more help and topics.
Dishwasher
Happy Holidays
Posted on Dec 24, 2010
heatman101
  • 43501 Answers
SOURCE: product 4 1/2 yrs old. Water does not completely
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Posted on Mar 04, 2011
After rinse fill the pump will not start
Hello, is there water in the bottom of your dishwasher? If there is water in bottom. Then try running the dishwasher throught another washing cycle. Now, if there is not water in the bottom of your dishwasher. Then the dishwasher has finished its washing cycle, rinsing the cleaned dishes. GB...stewbison
Sep 17, 2011 | Dishwashers
The dishes are not getting cleaned completely also I have notice some soap left at the end of the cycle.I tried to remove the bottom spin blade and top.Looks like it is too tight.Is it attached with...
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Feb 10, 2011 | Maytag MDB7100AWB Dishwasher
Water standing in tub
If there is a lot of water sitting inside the applicance, it's possible that the high water float switch has been activated and is preventing the dishwasher from running. Open the door, remove the bottom rack, dip as much water out of the bottom as possible with a shallow ladle or even tupperware container. When that is accomplished, shut the door and try to run a drain cycle. If the unit won't start, you may have to remove more water. You don't have to have the rack in place to run the drain cycle.
Jul 09, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Water left in bottom of dishwasher after cycle
a little water is supposed to remain in bottom so that pump will not lose prime
Nov 07, 2009 | Dishwashers
Poor washing quality and water left in the filters ets
My friend, that siemans is a night mare to open. Just done one recently. Anyway, looking at it simply, i would suggest you check the inlet water filter. if water is slow to come in it will cause this problem. Remoe the water pipe from the solonoid and look for sieve. clean it well retry.
Sep 21, 2009 | Siemens 24 in. SE25A266 ExtraKlasse...
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
So it sounds to me like it is your "pump" I work for an appliance parts dealer and it looks to me like the pump you need is originally part# 99002750 but then it changes to #6-917641....It runs about $57.00 and you can find this product at www.allbrandonline.com
Hope this helps!
www.appliancepartsonline.net
Dec 14, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Beumatic
The E4 code means - Overfilled. To much inlet water. Remove water manually from the tank pan and try operating a new cleaning cycle. Good luck !
May 31, 2007 | Baumatic 23 in. BDW14 Built-in Dishwasher
Dishwashers Logo
385 people viewed this question
Top Dishwashers Experts
Owen Barnes
