Question about Zanussi FJS1225W Front Load Washer
Change the door seal
Hello, does anyone know how to change the door seal of a zanussi fjs1225w? Thanks.
Not sure if its the same type but I just changed the door seal on a Zanussi ZWF1221W washing machine. It was a lot easier than I was expecting but this way does take a bit longer. Before starting disconnect the mains and water supply and drain hose. If possible move the washing machine out so you can get around it.
First I used a small flat head screwdriver to open the teeth on the outer door seal clamp that holds the seal in place. The old seal then peels off the front of the machine. You can continue the process without taking the front of the washing machine off but it is much, much easier to take it off if you can.
To remove the front panel unscrew the two bolts at the top corners of the back panel and slide the top cover off towards the back and lift it off. Then remove the two bolts that attach the plastic control panel to the front of the machine (either end of the top, front edge), remove the detergent dispenser drawer (you need to push down on a lever at the back) and take the screw out of the front of the machine (revealed when you take out the detergent drawer). Then carefully remove the control panel and the two bolts that hold the front panel on.
Then (very carefully as washing machines are heavy) lie the machine on its back and remove the three screws from the bottom that hold the front panel on. Then unplug the cables on the inside of the front panel that operate the door lock (its a plug with a plastic cover - just pull it out but don't pull the wires!).
Now you can lift the front panel off which is the key to making this job really easy as you're not trying to fit the new seal through the door which makes it really tight.
With the machine still on its back find the spring that stretches all around the seal to hold it on the drum and remove using a flat head screwdriver to pull it out of its groove. You can now pull the old seal off.
It's a good idea to put some fabric softener or liquid detergent around the edge of the new seal to make it easier to fit on to the drum at this point.
Find the arrow that points to the top and starting here attach the groove of the new seal to the plastic drum all the way around. You have to press quite hard but you can tell when its properly attached to the drum. Once this is done replace the spring so it sits in a groove on the seal holding it to the drum.
Now replace the front of the panel of the machine by doing the reverse of all the earlier steps (remember to reattach the door lock) and stand it back up on its feet (careful it's heavy). You can now replace the top panel of the machine (slide it on and replace the two screws).
With the washing machine back upright you can attach the front of the seal to the door opening of the front panel (the arrow should be pointing upwards). Then you can reattach the clamp that holds the seal around the door opening and then secure the teeth on the clamp so it's tight (I don't know if it matters where around the seal the clamp goes but mine's at about 7 o'clock).
Now all you need to do is reattach the drain hose, water supply and mains and test it doesn't leak. A rinse cycle uses the most water apparently so it might be worth using that.
Hope this was useful.
Posted on Jul 24, 2009
Replacing the door seal on Zanussi 1416W
No need to remove front cover.
Best way round the prob is to stretch the spring, this will make it easier to fit, it will help if you can get someone to assist in holding the spring, so that it does not come off as you are feeding it around the seal.
Don't stretch it to much, as it it will then be to slack, and may come off during washing.
Good luck.
Please rate my solution.
Thanks.
Aug 06, 2009 | Zanussi FJS1225W Front Load Washer
Main bearing gone
This is joyce
Hey dont do it seriously unless you are really good, mine went out and it took them 2 hours to fix mine, very ugly.
but if you are bent on fixing it go to zanussi.com and put in your model# and download your manual and it should tell you how to do this.
thanks
joyce
Feb 03, 2009 | Zanussi FJS1225W Front Load Washer
I have problem E40 on Zanussi zwd 1680 w
E40 is door interlock error, it means that either the door interlock is stuck or faulty, or the wiring from door interlock to main control board are not connected.
Oct 03, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi fjs1225w
this comes up all the time!!
disconnect from mains.
remove plastic clamp that holds seal to cabinet and peel the seal away from the cabinet
the seal is held onto the tub by a circular spring. force the seal downwards and outwards to start the seal away from the tub and peel off complete
on new seal, lubricate the slot that goes onto the lip of the tub with washing up fluid.
starting at the top, push the slot in the seal onto the lip of the tub. goindg in both directions, push the rest of the seal onto the lip of the tub. this is a knack so be patient.
when completely on, next step is to refit the circular spring. this is quite difficult and an extra pair of hands helps. the spring slips into a groove on the outside of the seal.
refit the seal onto the cabinet - this is easy - and refit the plastic clamp.
test for leaks on rinse as the water level is higher - water will be foamy till washing up fluid is wased away
Oct 02, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W won't spin
motor brushes can be replaced in situ but you will find it easier to remove the motor.
take the rear cabinet half off and undo electrical connections to motor. motor is held in by 4 bolts. undo and motor will slip out.
brushes are located towards the end away from the pulley and held in by 2 small bolts. undo, withdraw brushes and see if badly worn
easier way is to check continuity across the brushes with the motor in situ using a multimeter
Aug 31, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi fjs1225w nasty smell around door seal and inside machine
Are yo;u susing front loading detergent? My smell went away when i switched.
May 14, 2008 | Zanussi FJS1225W Front Load Washer
RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Dec 11, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi front load washer door seal
Keeping the door open after your wash would help in keeping the interior dry. Do not push the door shut, just leave slightly open. Only before you begin your wash, check to see your cat is not inside.
Oct 13, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
630 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
