Question about Frigidaire GLTF2940ES Front Load Washer
I have a frigidaire gallery front load washer need help
I have a frigidaire gallery front load washer when it is in the spin cycle it sounds like it is hitting some thing in side i think it is off balance but i dont know.. neep help please. and if it is how to i balance it
  • lhamby2203 May 23, 2009
    im sorry but it still makes the sound just not as loud any other suggestion please
    President:
  • 1,185 Answers
Run the machine on a cycle with no load in it (no soap powder either)
If it makes the same noise when there are no clothes in it then the suspension legs have given way or the counterweight has come loose.
You will need someone who knows what they are doing to repair it
Posted on May 23, 2009
  • Tom
    Tom May 24, 2009
    It is unlikely that the drum has come loose from the backplate
    If the noise is a rumbling noise then the drum bearing may have failed
    Put your hand inside the machine and try to lift the inner drum upwards using the front edge of the drum
    If it lifts very easily for a 10mm or more before you meet heavier pressure then the bearings may be shot.
    Rotate the drum by hand is it smooth or does it sound rough again that signifies bearing problems.
    If all that checks out then you are back to suspension legs and counter weights which require a technician
I have the same situation. It is clearly in the "inner drum" as the outer drum shocks and springs are all fine (I opened the back to see).
Is there no fix it that I can do if it is inside the drum?
Posted on Nov 11, 2009
Frigidaire gallery washer smoking and not spinning
Sounds like you either have something in the pump or maybe the belt is slipping on the pulley.
Aug 05, 2015 | Frigidaire Gallery GLWS1339EC Top Load...
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
Washer cuts off at 7 minutes and will not do the
It be the carbon brushes are worn down on the motor, when it goes into the final spin.
Mar 09, 2010 | Frigidaire GLTF2940ES Front Load Washer
Sounds like a bangin when its in spin cycle need help please
If this is a front loading washer, the spider arm is broken at the back of the drum. Big bucks to repair this. You might as well buy a new machine.
May 23, 2009 | Frigidaire Gallery Supreme Series...
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer is extremely loud
defective back bearing and spin basket..onthejob
Feb 03, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
638 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
