Question about Maytag MAH6700AWW Neptune Front-Load Washer
Maytag MAH6700AWW Humming Sound
It will not do anything in any cycle it will humm like it is trying to do something but never will
    President:
  • 1,185 Answers
Can you see water in the drum ?,No water = no action Check water supply
If there is water in the drum does it drain out at some point.
Sequence = Fill, Agitate, Heat, Wash, Drain, Spin etc.
If it fills then it may be a belt has snapped and the drum cannot turn , need to take the covers off to look.
Remove power before taking covers off !!!!
If the belt is OK then it may be the heater which has gone open circuit, try a cold wash or a rinse cycle to test that.
Posted on May 23, 2009
I have a frigid air gallery series washer that lights up and just humms,it will not start cycle. I have checked pump and motor isn't ether one of those making humm sound
Good Afternoon Cloy,
I understand that you are getting a humming sound on your Frigidaire washer, and it will not start a cycle. I also see that you've checked the pump as well as the motor, and neither of those is making the humming sound. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine what is causing your appliance to make that humming sound and not run a cycle. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire Washing Machines
My washer is making a humming noise and will not run. there are currently clothes and water in the washer
remove 4 screws on the rear panel and then remove the cover, you can see the drain pump remove both hoses on the pump,it is probably plugged up,if it is they wont drain or do anything
Apr 30, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Won't spin out and makes a humming noise
Wait for your handsome husband to come home and have him fix it. jk
Nov 09, 2011 | Maytag MAH6700AWW Neptune Front-Load...
WHY WASHER LEAKS AND HUMMS WHEN WATER IS RELEASED BEFORE RINSE CYCLE AND LEAKS UNDER THE BOTTOM OF WASHER.
Possibly because the seal on the pump has been compromised. There may be a blockage( kids sock or smaller item that has been sucked into the pump. The humming is from overload in trying to **** water with air from the breachh of the seal.
Sep 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
Jun 20, 2009 | Maytag PAV2300 Top Load Washer
Freezer not freezing on m,aytag mfd2560hes
hi andy, based on your story, i think the humming sound is coming from the compressor trying to start and the clicking sound is when the overload trips and make that clicking sound to turn off the compressor but it does resets itself so it would humm again after a few minutes and tripps off again..try to unplug the unit for a day to cool off the compressr and then plug it back. if it will happen again, you need to replace the compressor. i hope i was able to help..
Jul 07, 2008 | Maytag MFD2560HES Bottom Freezer French...
Ice Despenser Just Humms
  • the motor could be bad, the humming sound is a sign of that.
  • but i would suggest taking the auger out and make sure nothing is jamming it in anyway.
  • remove all of the ice cubes, ice buildup, or anything else that is not supposed to be in or around there.
  • it is worth a try before you start spending money. :)
Jul 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
Maytag Netune Mah4000AWW
Makes a loud humming noise. Does the machine go thru its cycles ? Is the humm ther all the time ?
Jan 06, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag MAH6700AWW Neptune Front-Load Washer Logo
208 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
