Question about GE Refrigerators
THE REFRIGERATOR IS DREPPING WATER INSIDE FROM UNDERNEATH THE FREEZER.
The refregirator is drepping water from inside underneath the freazer.
This just happened to me.......in my case - ice formed in a section in the back of the freezer clogging up the place where condensation(?) is supposed to drain off...it has something to do with the frost free feature.....when that became full - water then dripped inside the fridge. I called the manufacturer..they sent someone out who fixed the problem and then put something in the back of the freezer so this would never happen again. Sorry, this isn't a technical response but it sounds exactly like my situation. hope that helps a little.....cost about $200 to fix it...still better than having to buy a new one
Posted on May 23, 2009
Frig-freazer. mannfactured 03 collecting water
The drain tube is attached to a tray at the base of the evaporation coils on the rear wall of the freezer section. You gotta remove the access panel to find and clear the drain. I recently worked on a frigidaire model and made a crude video:
Jul 17, 2013 | Frigidaire Refrigerators
My Refregirator is not cooling properly
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 13, 2010 | Samsung Refrigerators
The refregirator will not get cold. The light is on and the freezer is staying cold.
heatman101
Sep 04, 2010 | Whirlpool Refrigerators
My refregirator isnot making defrost?
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 23, 2010 | Amana Refrigerators
Water leaking from under the freezer
Until defrosting the block of ice you canot see if is a hole or crack in the bottom. But I suppose is leaking from the door gasket under the pressure of the ice inside. Anyway, if you want to keep alife your refrigerator, better unplug it, defrosting and clean it before complete annihilation.
Sep 10, 2017 | Frigidaire Refrigerators
Water is leaking from top part of freezer down to bottom of inside of the frig. Frost is on the top of the frig in the frigerator.
FIRST STEP: UNPLUG THE REFRIGERATOR. AFTER IT'S UNPLUGGED, DO THE FOLLOWING:
Remove the food from the freezer compartment and place inside the refrigerator temporarily.
Remove the bottom panel and back panel from inside the freezer compartment. You will probably notice that the bottom of the inside of the freezer is covered in ice. Use hot water (not boiling) from the tap and pour it on to the ice that is formed on the inside of the freezer compartment to melt the ice.
CAUTION: DO NOT USE A HEAT GUN TO MELT THE ICE AS IT WILL MELT THE INSIDE OF THE FREEZER COMPARTMENT. ALSO DO NOT CHOP AT THE ICE WITH A SHARP INSTRUMENT OF ANY KIND AS THIS WILL PUNCTURE AND DESTROY THE INSIDE OF THE FREEZER.
If you have a wet vac, you can remove the melted water using the wet vac. Or you can use a towel to mop up the excess water. You will still have to pour hot water onto the ice until all of the ice in the freezer is melted. Patience is key as it takes time to defrost all of this ice.
You will see a drain hole in the back of the freezer compartment that is still clogged with ice. You will need to continue to apply hot water until the ice has completely melted.
Note: When the ice in the drain breaks free, you will see all of the water disappear as it empties out.
In Whirlpool refrigerators, the water runs to a tray underneath the refrigerator. You will hear the water empty out into that tray. Then you will know that you have completely cleared the ice from the drain pipe in the freezer. To double-check this, take a small cup of warm water and dump it into the drain hole and you will see it visibly disappear and run into that tray underneath the refrigerator.
Replace the freezer panels back into the freezer compartment and plug it back in and return your freezer items back in to the freezer and you should be all set.
Oct 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refregirator fresh food compartment not cooling off
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sjf
Sep 20, 2009 | Maytag MZD2766GES Side by Side...
My refregerator is sid by sid, not making ice and is not cooling
if the fan motors and everything is else is running proprerly, i wouldnt be suprised if you needed to have some freon added to the system.
Apr 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Freezer and refregirator are both down
sounds like the defrost timer is malfunctining and leaving on the heaters that melt the ice. or it may have just came out of defrost. take and feel the lines where they go into the compressor in the back. watch out for the fan blade when doing this. one should be cold and one hot. if not then the compressor may not have enought refrigerant in it. anothe thjing to check is the coils are they clean. the oines that are underneath are what i'm talking about. if they are not oyou will have toi clean them. good luc and let me know if you need more advice.
Jan 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Samsung fridge freezer model no: RS21DCNS
how do we disconnect the water line to the freazer
Mar 24, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
