Question about HP PSC 2210 All-In-One InkJet Printer
Printer output is a blank page
When attempting to make a photocopy or print a document, the pages all come out completely blank. The print cartridges move back and forth as if printing, but no ink is put on the page. Any thoughts or suggestions?
    Scholar:
  • 103 Answers
* Please check with the ink level in the Catridge.
* Be sure that catridge nozzle is not dry or dirty.
* Check wheather ink nozzle is clogged/ damaged if so use rubbing alcohol to clean them.
* Try printing by replacing new catridge.
Thanks,
Appereciate to rate as "FixYa"
Posted on May 23, 2009
Lexmark printer not dispensing ink
First, make sure you are using genuine Lexmark cartridges.
Second, try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
If the firmware update doesn't help, please perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If it still doesn't help, please contact our technical support team.
Jan 08, 2013 | Lexmark Impact S305 - multifunction ...
Brother MFC prints blank pages
Try disconnecting power completely, not just turning off. Wait a few minutes and reconnect to power
Also, your print queue may be full with failed attempts at printing. The printer becomes confused and does not know what to print next. You should be able to flush the queue at the computer, but the complete disconnect and reconnect may accomplish this
Sep 04, 2012 | Brother MFC-790CW Multifunction Printer
HP color laserjet 2840 for Mac -- Pages print but are totally blank. Appreciate if you can advice A.S.A.P
  • The sealing tape might still be in the
    print cartridges.
Solution "Verify that the sealing tape has been
completely removed from the print
cartridges."
  • The document might contain blank
    pages.
Solution "Check the document that you are
printing to see if content appears on all
of the pages."
  • The device might be malfunctioning.
Solution "To check the device, print a
Configuration page."
Jul 06, 2011 | HP LaserJet 2840 Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Prints and photocopies blank pages
a bet your problem is the drum cartridge,on it´s back exists a lever,rod, or something like that ,if it´s bent will not open the laser and give blank pages ,open the left door and check if it´s straight.
Jun 12, 2009 | Canon iR 2022 Printer
Black ink will not print (new out of box).
If cleaning doesn't work you should talk to your retailer or Brothers support. Don't think they can expect you to use up all ink cleaning cartridges when the machine is straight out of the box..
Jun 01, 2009 | Brother MFC 6490CW InkJet Printer
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
Blank pages
You might want to start by doing some general print quality troubleshooting, including printing a test page. The test page should give you an indication if you have issues with print cartridges. Also, some printers may not print at all if even one of their cartridges is empty:
Correcting Print Quality Problems
The other thing that occurred to me is that your document feeder could be pulling in more than one sheet of paper at a time, this means it would output blank sheets as well. Here's a web page that describes the problem and what to do about it:
Automatic Document Feeder Error
Hopefully the answer to your problem is available in those web pages. Good luck.
Sep 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Prints a few lines, then blank
This is worth attempting to discuss with Lexmark's Tech Support line. Or take a look at www.fixyourownprinter.com
May 17, 2007 | Lexmark X5150 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
202 people viewed this question
Seeker5211
Seeker5211
