Question about Mantis Little Wonder Tiller/Cultivator #7262h
Spring replacement how do I get the spring back in after replacing a pull cord on a mantis tiller?
  • 15 Answers
Replacing the spring on this tiller can be tough. You have to get the tension spring set into the stop and partially wind the tension (by turning the cord pulley) and THEN attach the cord before completing winding the tension spring. It took me about an hour to figure out how much preset of tension was needed before I was able to get it to work. You have to partially preset tension because starting from zero will not fully rewind the cord.
Posted on Jun 03, 2009
I have a troy built tiller/cultivator and the pull cord is not sparking the engine to start. very easy to pull. what do you think the problem is. you can pull it and it just goes right back . could the clutch be bad. thanks
Posted on Apr 03, 2010
How do I fix a mantis tiller that wont start
First, check your fuel lines to ensure they are not brittle from using gas with ethanol. I had to replace my fuel lines last spring.
Prime the carb and pull a couple of times. Pull the spark plug and see if it is wet or damp. Dry and clean the plug. If you have some starting fluid, give it a shot - replace the plug and wire, and give it a pull.
Mar 09, 2015 | Mantis Garden
MANTIS tiller 7225-00-02 starter cord won't retract
take the crank rope cover off and in between rope reel and cover there is a wind up spring either its broke or has come out of its slots.
Aug 16, 2012 | Mantis Garden
Starter cord
remove top starter assy. cut grip from old rope ease rope into spool,
when slack remove center screw and carefully pull out spool, tie knot in rope and thread into spool, wind rope [make sure correct size rope]
around spool until full,carefully turn spool into spring 1 turn then replace screw. put rope into notch on spool and wind up 3-6 turns,
replace grip
May 19, 2012 | Mantis 2-Cycle Tiller
New mantis worked perfectly last season. Stored it for the winter. Tried to start it this spring. Pull cord is frozen up. Can't pull it out.
First, call Mantis and get their advice. It may be covered under warranty (I believe it comes with a 2 year warranty). If not under warranty remove the spark plug and try to pull the starter rope. If you can pull it out squirt a little 2-cycle oil in to the spark plug hole and pull it out several times before reinstalling the plug. Then try to start it again. If you can't pull it out after removing the plug try removing the engine cowl that contains the starter rope and see if you can pull it out then. If you can't then there is something wrong with the starter rope mechanism. Try some oil or Liquid Wrench on the spring to see if you can free it up. If you can then the piston may be seized. Again, squirt a little oil ni the spark plug hole. Take a ratchet wrench and socket to put on the crankshaft nut. Try to turn it. Do not apply to much force. I would send it back to Mantis for repair or replacement unless you are mechanically proficient enought to take the engine apart. If you have been using the correct fuel/oil mixture this should not happen.
May 21, 2011 | Mantis 2-Cycle Tiller
My pull cord will not retract
The coil spring has either broken or come loose inside the pull rope housing. You must disassemble the housing to fix it.
Jim
Aug 31, 2010 | Mantis 2-Cycle Tiller
CAN THE SPRING BE REWOUND ON MY MANTIS TILLER THE CORD BROKE, AND WHEN I WENT TO RE INSTALL THE SPRING CAME OUT
Go to your local small engine supply store with the model an serial numbers. you can buy the spring all ready wound and in a metal container that will drop right in and you will be set togo.
May 01, 2010 | Mantis 2-Cycle Tiller
Trying to put on pull cord on tiller.
you remove the cover, bend three tabs and the wheel will come out. Replace the cord in the manner that it is removed, rewind spring and install wheel, then bend the tabs back down.
Jun 22, 2009 | Mantis 4-Cycle Tiller
Mantis tiller will not start
did it also run out of oil, because it seized like it did you might of burnt the engine
May 31, 2009 | Mantis Tiller
Handle ripped off Mantis tiller
Good job on the cord replacement. Most people take the cover off the spring and then find out it is nearly impossible to get the spring tension set. I have personally repaired dozens of these cords that have been messed up by owners that did that.
If anyone has this problem, just do what this post says...remove the assembly and turn the pulley until you can get to the part of the cord that is broken...grab the end that is broken after you get it out of the opening with a vise grip and pull the cord out fully and lock the recoil spring with a vise or vise grip (but don't crush it)...then replace the cord and hold the end of the cord pull fully extended and remove the lock and allow the spring to recoil...and reinstall the assembly.
Simple, but THINK before you take the housing apart. It is REALLY TOUGH to reset spring tension properly.
Apr 26, 2009 | Mantis 2-Cycle Tiller
Pull cord stuck
it sounds like the recoil spring in the "housing" is jammed( or something is broken) youll have to take this apart without breaking it. you may have internal engine damage if it was unusually hot and the pullcord jammed. try using a richer oil mixture for fuel also if you fix the pullcord. hope this helps, keep me posted.
Apr 18, 2009 | Mantis 2-Cycle Tiller
Mantis Little Wonder Tiller/Cultivator #7262h Logo
1,249 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
