Question about Wayne Water Systems Wayne RECONDITIONED 57032-RP1 1/3 HP 2,800 GPH Pedestal Sump Pump
No information on Wayne 55701-RP1
How many GPM is this pump rated for?
  • 44 Answers
This isn't a valid Wayne pump model number according to Wayne's website. Please double check your pump and visit:
http://www.waynepumps.com/producttype.aspx?pt_producttypeid=8
Posted on May 24, 2009
Wayne well pump
How to take apart
Brian, Could not find a lot on this pump, maybe download manual or contact Wayne at the link below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Literature Wayne Pumps
Apr 01, 2016 | Wayne 6624027 1/2Hp Shallow Well Jet Pump
DO YOU HAVE PARTS FOR A WAYNE RSP130 PUMP
Wayne,
This site offers to help you solve problems with information, but it doesn't sell parts. Sorry.
Nov 06, 2012 | Wayne RSP130 1/3HP SUB SUMP PUMP
What is max. gpm and pis of the wisperflo punp 011773
Your question sort of requires two answers as the max flow and max psi are not the same yet relate to one another.
The max flow is ~105 gpm at ~26 ft./hd or 11.3 psi.
The max psi (head) the pump can operate under is 40 psi or ~85 ft./hd at which flow is ~35 gpm.
In other words, in a pipe system with low resistance it moves up to 105 gpm and in a very complex system with lots of elevation changes and a lot of resistance the pump will move about 35 gpm.
PSI as read on a gauge on a filter attached to this pump will NOT be the same as the ratings I am giving you here.
John
Aug 24, 2011 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Have a homelite AP-125 - UTO1709 F, want to know how far it can pump water uphill
Your best bet is to ask Homelite directly for the pump curve. Since Homelite does not appear to offer it anymore I could not find anyone who published the information, hence the referal to Homelite. A typical pump curve for a small pump like this will show GPM or GPH based on several discharge heights. You do not need to consider the overall run of pipe or hose but only the total change in height. In other words, pumping thru 150' of 3/4" hose up an incline that has a total rise of 12' would end up delivering the GPM for 12' on the curve or something very close anyway.
Contact Homelite here.
John
Jan 04, 2011 | Homelite Plumbing
Just wondering what the flow rate is Aquaflo XP2 Spa Pump 2.5hp. Reason I want to know is I want to use the pump as a circulation pump for a pool. thanks
There is no way to know the flow rate of your installation beyond a guess ... I guess you are pumping about 95 GPM with a 2.5 hp motor ... a 2 HP moves about 75 to 80 GPM. A 1.5 moves about 60 to 80. There are lots of variables least of which are accessories in the line ... chlorinator ... heater ... filter and its cleanliness ... etc. Other vairables include pipe size ... distances water pumped, number of turns - fittings - restrictions, etc. To get a good idea of the flow rate (important to know when calculating 'turn over' rates) get and properly install a flow rate meter.
Thanks for your interest in FixYa.com
If you found this information helpful, the courtesty of a positive vote will be appreciated.
Aug 28, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I have a 3/4 Hp Model C48B49C09 3450 A.O. Smith pump and need to know its G.P.M. output.
It should have a tag on pump with information on it concerning hp and gpm.
May 11, 2010 | Plumbing
1/2hp Hayward Pump for existing inground pool
you will be fine with the 1/2hp. The Hayward will move quite a bit of water as well. It may not move as much water as the 3/4hp but it's very close and the 1/2hp will cost a little less to operate so if anything, you may just have to run it for one additional hour per day to compensate. You will be surprised how much water a 1/2hp will move. The only issue with smaller pumps is if you have pop-up cleaner heads or a suction driven automatic cleaner such as a kreepy krauly, however, if a 3/4hp will run it, a 1/2hp will run it as well. You can install a larger motor on the super pump but it will not move more water unless you upgrade the impeller as well. Just make sure you don't use a bigger impeller than what the motor is rated for because it will strain the motor and cause it to overheat. Hope this helps.
Feb 20, 2010 | Hayward SAND FILTER, PRO SERIES
What size submersible pump do i need to deliver 20000l/hr ,pump is 50 meter deep in bore hole.
That's a lot of water. In the U.S. , pumps are rated in GPM (gallons per minute. Your 20000 liters per hour converts to 88 GPM. So you need to find a pump that can produce at least 88 GPM.
Jul 11, 2009 | Flotec 1/2 Hp 3000 Gph Utility Submersible...
Clothes washer
I could not find a definite answer for you, but I know that the wash tub holds roughly 35 gallons on a full load. You can calculate the time it takes the washer to completely empty a full load to see how long it takes. If it takes 1 minute for the wash tub to empty on a full load, then you know the GPM for the drain pump is about 35 gallons per minute. If it takes a minute and a half, the rate is about 23 gallons per minute. If it takes 2 minutes, then the rate drops to about 17.5 gallons per minute. Get the idea? I hope this gives you the information you were looking for. Let me know if you have any further questions.
Feb 20, 2008 | Kenmore 24032\24036 Top Load Washer
Wayne Water Systems Wayne RECONDITIONED 57032-RP1 1/3 HP 2,800 GPH Pedestal Sump Pump Logo
170 people viewed this question
Top Wayne Water Systems Electrical Supplies Experts
Steve
Gene Haynes
Are you a Wayne Water Systems Electrical Supply Expert? Answer questions, earn points and help others
