Question about Sharp Notevision XG-NV6XU Multimedia Projector
Sharp LCD Projector has a blue line on the screen
This is an XG-1000. Sporadically, a thin blue line appears on the screen right in the middle. I have cleaned the filter that is easily accesible under the unit. LAst time I did that, there was no blue line. But today it's back.
Any idea how tro get rid of it?
  • Anonymous Dec 30, 2007
    DFFFF
  • 103 Answers
SOURCE: Sharp 42" flat screen LCD T.V.
You have a bad buffer ic,which is part of the lcd panel.Definiately call sharp to get it repaired.If it doesn't have a warranty,persistence through sharp will get you results.
Posted on Mar 07, 2008
  • 53 Answers
SOURCE: Thin blue line
I am a Sharp Servicing Technician. You posted this before. Ive got the same model TV as you do LC46D62U. I think the line you are experiencing is simply the broadcast. I notice it on some HD shows that broadcast the side bars. (Always on the Ellen Degeneres Show). Ive taken some picture.
1) Here's the line on the left that i experience
2) Later on in the broadcast, it goes away.
One way to check if its a TV problem or not. When the line shows up again, hit the MENU button on the remote. If the line appears to be "behind" the menu, then it is simply the broadcast.
If the line appears to be "on top" of the menu or shows right through the menu, then it is a TV problem.
Im thinking the reason it takes hours for hte line to appear is because it only shows up on certain shows or certain HD broadcasts.
Posted on Mar 28, 2008
freetek
  • 5568 Answers
SOURCE: green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Posted on Jul 09, 2008
if someone found a solution for the verical line please post it. the laptop has never been hit and the vertical line just showed up there...
Posted on Sep 28, 2008
SOURCE: Where are the fuses in a Sharp xg-nv3xb notevision3 projector
Main line fuse is on the board where the ac cord plugs.
The caps in the power supply usually leak and explode after 5 years, blowing the fuse. Solution is to replace the power supply and lamp ballast boards. Expensive repair.
Posted on Dec 17, 2008
I was givin a sharp LCD projector XG-H400U and I am having a problem getting it to turn on. When I plug it in the lamp flashes then nothing! Is the lamp bad or is something else wrong?
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Aug 14, 2011 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Missing blue region
It sounds like the bulb overheated at some point. Time to replace the bulb.
Oct 31, 2007 | Sharp Notevision XG-NV6XU Multimedia...
I replaced the lamp in my Sharp XG-E3500U and there is lines in the picture now. How do I solve this problem?
mostly, this is caused by a default of the lcd screen inside, if so, you must replace it, if your model is using 3 lcd screen, open the cover, disconnnect one of them , run the projector, if you don't see lines, power off, reconnect it and disconnect the second, till you see the lines, so you can localise the default one. you also can try to check the lcd screen connector, disconnect, clean, reconnect
Mar 04, 2011 | Sharp XG-E3500 Multimedia Projector
Sharp XG-E650UB LCD Projector
Absolutely, they are designed to do so. You will need a svideo cable for video if your laptop doesn't have a parallel port for external monitor. Most projectors have svideo and parallel ports to use them as monitors. If using the external monitor option you select the alt/enter buttons to display on projector.
Aug 07, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
May 21, 2009 | Sharp XG-E3500 Multimedia Projector
Yellow in center of picture
The blue device is dying allowing green to shine thru instead of white. Very common problem called color decay. Happens on average about evey3-4000 hours. I suggest next purchase a dlp product, they are immune to this problem. Good luck
Mar 29, 2009 | Sharp Notevision XG-NV6XU Multimedia...
I inherited a Sharp XG-NV2U LCD projector. When I turn it on I get a blue screen with a blurry white square in the middle, which I assume is the menu. Have adjusted focus but doesn't change. Any...
lcd panel or palarizer is failed
Have a nice day!
Jerry
Lampdeng Limited
Mar 28, 2009 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
Sharp notevision xgnv6xu oval yellow spot
I have a similar issue with yellow pattern on the left and top right of my screen. Took it apart and found the blue lcd had damage that matched the yellow area that was projected. I thought it was the lens but it was the blue lcd .It has gone bad and no replacement. Are you interested in selling the bulb or the whole projector? I have since purchased another projector and am keeping the bad one for spare parts. Hope this helps..Ben
bgrenco@aol.com..
Jan 18, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Sharp XGP25X Projector has large blue smudge on Screen
This is one of two things. Most likely there is a piece of dust or other obstruction right on top of the blue panel. I'm guessing that your smudge is in the lower center of the screen - that is where these usually occur. The other possibility is that the blue LCD panel is starting to deteriorate and the components separating. This is extremely expensive to repair and Sharp will end up giving you an estimate that approaches the replacement cost for a comparable new projector.
Dec 12, 2008 | Sharp Conference Series XG-P25X Multimedia...
Sharp Notevision XG-NV6XU Multimedia Projector Logo
244 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
