Question about Panasonic VDR-D300 DVD Camcorder
Panasonic VDR-D300 Camcorder cannot play DVD-RW (VR format) on PC
I am using a panasonic DVD-RW disc (VR format) for my video recordings. When I try to playback or copy onto my PC (Windows XP Professional) usung the supplied Panasonic software, I am unable to view any of the footage and get the following Error Messages "Your version of DLA can read files on this disc but you will not be able to edit or add to them". The other error message reads The disc in drive F: cannot be used (Format type Unknown) Insert AV format (UDF 2.0 type) DVD-RAM/DVD-RW disc in the drive. I have verified that the driver has been recognised properly. The other issue however is thet on the camera unit menu, I do not have the USB Function - PC connect option as it suggests in the instructions.
  • rscali15 May 24, 2009
    Thanks jaja928. I assume I will need to buy a new Panasonic Camcorder specific USB.
    Problem Solver:
  • 6 Answers
Your usb cable has malfunctioned
Posted on May 23, 2009
Please i have a problem, i can't read video from my camcorder directely when introduicing CD RW in my computer. i have a panasonic VDR-D160 and its not possible to transfer diveo to edite film. how to do,...
Hi!
The driver for this device can be download from the link below
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/DVD-Camcorders/Drivers-Downloads/model.VDR-D300.D#ts
click the link. download the driver and the instruction manual.
Install the driver on your pc. You can try this driver on windows 98, nt, 2000 and xp. But this driver is specifically designed for windows vista.
I hope this works for you.
Post back if you still have questions.
mace
Dec 13, 2010 | Panasonic VDR-D300 DVD Camcorder
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
Can't upload video from Panasonic VDR D210 to computer
My Panasonic Camcorder D210 broke and can't finalize my discs. What do I do?
Sep 26, 2009 | Panasonic VDR-D210 DVD Camcorder
INCOMPATIBLE DISC
Good news.. you should be able to put the disc back in to the device that you recorded in on... and go to the menu to do the finalize... in fact, you may be able to add more to you disc prior to the finalize process if you want...
once it's finalized you should be able to view on other equipment... your files should all be there as well.
Let me know how you do!
May 26, 2009 | Panasonic VDR-D300 DVD Camcorder
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
Don't forget to rate this solution once you've tried it !
May 11, 2008 | Canon DC210 DVD Camcorder
Changing the mode to use USB on panasonic VDR-D100 DVD camcorder...
Try using only DVD-RW disc (not DVD ROM/-R/+RW) and format as "Video" mode. When you are done shooting finalize the disc. Then iMovie or your movie maker should recognize the video.
May 05, 2017 | Panasonic VDR-D100 DVD Camcorder
Camcorder Problem
You need to do formatting on the disc when using it for the first time. Remember, formatting needs to be done by camcorder. If you used the disc before and formatted it on different machine - it won't work.
Jul 27, 2007 | Panasonic VDR-D300 DVD Camcorder
Panasonic VDR-D300 DVD Camcorder Logo
1,143 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
