Question about Hitachi RAS-09UH Air Conditioner
Air con not cold
I have a 7 year-old inverter air con system with 4 blowers. Yesterday all 4 blowers suddenly could not produce cold air ie. there was the usual 'wind' from the aircon but it wasn't cold. Do you think there's a problem with the compressor?
    Novelist:
  • 166 Answers
Yes, so as not to be repetitive (as others have had the same problem), here's a simple article that percisely explains the possible causes of your AC not cooling:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Also, if need be, take advantage of the link towards the end for four free quotes from technicians if you find yourself need to get one. (You don't want to needlessly be charged for just someone's coming over only--it could cost a lot for no substantive action.)
Brad
Posted on May 25, 2009
I have a R410A Inverter Split system that has stooped suddenly and is now displaying E1, what does this mean/ Thanks Lorena
Not 100% sure but an E1 error on a unit which is sourced from the same place as Electrolux air cons, means that the pipe sensor on the indoor unit has failed. You will need to confirm this with Electrolux. They carry a 5 year warranty, so you may be in luck.... hopefully
Jul 16, 2011 | Electrolux Heating & Cooling
Cleaned coils/cage, a/c blows better but no longer cold
It would not be a slow leak, but you don't know, if your brother punchtured the coil. If the unit is less than 5 years old, it should be still under warrenty. If it is the coil, depending on the make . say lennox heat pump. the coil is $1,700.00, Coils are all different prices. It might be cheaper to replace whole unit. SORRY
http://www.heattransfertechnology.com/
Here are coil prices
Jul 04, 2010 | Whirlwind FH-778 Air Conditioner
I have year 2000 (Old shape) audi 1.9tdi and the air con has been topped up but is still not working.
You may need to check the thermostat and have your clutch bearing checked for your ac pump.
Jun 01, 2009 | 2000 Audi A4
My blower only works on setting 123 + air con not that cold
You have a resistor array assembly going out. What you described is typical of the first resistor going out and over loading the second, which goes out and overloads the third. Replace the HVAC resistor array. Don't buy a used one. Spend the extra money on the new OEM dealer item. Good luck to you.
Apr 20, 2009 | 2000 Jeep Cherokee
Bmw 318i air con switch
the light should be on when air con is working. only works when the blower is on ,ie heater blower switch on=air con light lit up = aircon working.
Oct 16, 2008 | 1997 BMW 318
Older subzero side by side not cooling
At sixteen years old it is almost through its life span. A change in ambient temperatures will change internal system pressures. Make sure the condenser is cleaned well. Use a vacuum cleaner to clean off the condenser, then blow it out with compressed air. Even though a condenser looks clean on its surface fins there may be dust down in between the fins.
May 05, 2008 | Sub-Zero 690 Side by Side Refrigerator
Air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Dec 10, 2007 | Heating & Cooling
Hitachi RAS-09UH Air Conditioner Logo
217 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
