Question about Magicard Alto Card Printer
Magicard Enduro Printer problem
I have a Magicard Enduro printer, installed in Vista Operating System. Whenever i'd try to print it would prompt "Wrong film type". I was able to install to another PC and works perfectly fine. I've try to install and reinstall everything in my laptop but still not workking. hope anyone can help
  • vdvd May 11, 2010
    Is the Vista 32 bit or 64 bit as the driver currently only operates with 32 bit systems
5 Suggested Answers
SOURCE: Static Warning light
i also have the same problem, my id printer is magicard rio. I already did the reinstallation but still the the red light still open
Posted on Sep 16, 2008
magicard
  • 71 Answers
SOURCE: MagiCard Tango 2 Badge Printer
Hi There,
This is very a very common problem!
Fortunately, it's really easy to fix too;
Go to your 'Printers & Faxes' folder. Right-click on 'Magicard Printer Series'.
Select 'Properties'. Click on the 'Device Settings' tab.
Select the correct printer model in the drop-down list (Tango 2);
I suspect you currently have 'Tango' selected.
I hope this helps.
With Best Regards,
MC.
Posted on Nov 23, 2008
magicard
  • 71 Answers
SOURCE: i cant print cards using cardfive software and magicard rio print
Hi There,
First of all, for Windows Vista, you need to be using the very latest driver (V6.02).
You can download this by following the link below;
http://www.magicardonline.net
Just enter your printer's serial number in the QuickSearch box.
Please Note: - With CardFive software, you need to scroll all the way down to the bottom of the printer list, then select the printer driver with the Windows logo next to it called 'Magicard Printer Series'.
If you still can't print from the CardFive software, can you print the Windows test page?
I hope this helps.
Regards,
MC.
Posted on Mar 31, 2009
  • 7 Answers
SOURCE: enduro magicard printer all that comes up when
vcbvvcbvbvc
Posted on Feb 17, 2010
How to reset magicard enduro duo printer
hello
I have a big problem
my magiccard printer both sides
give my the back said (black photo )
How I can fix that please
Feb 02, 2014 | Magicard Printhead Enduro & Enduro Duo...
I GOT COLOR RIBBON BUT THE PRONTO SED TO ME THAT A HAVE TO CHANDE BUT THE RIBBON IS NOT DONE YAT!!
Hello fabiogb_765,
Did you notice an error number when your printer tells you that it is out of dye film?
The error number is important.
Regards,
MC.
Jan 11, 2013 | Magicard Enduro/pronto Ymcko Color Ribbon-...
Magicard Alto driver for Vista (NON E serial)
Hi There,
Go to;
Enter your printer's serial number in the QuickSearch box.
Follow the instructions for installing the 'Alternative' driver.
This driver will work with Vista.
May 27, 2012 | Magicard Alto Card Printer
I cannot install on my my printer, i do not have cd but I have downloaded from HP website ...operating system windows xp doesn't not detect printer...help!!!
Access the manufacturer's web-site: http://support.hp.com
Enter the model-number for your HP printer, and do the search.
Select "downloads".
Select "device-driver".
Select your Operating System (Mac? Windows Vista?)
Download the device-driver.
Install the device-driver.
Connect the printer, when prompted to connect it.
Print a test-page.
Jun 26, 2011 | HP Office Equipment & Supplies
I cant print cards using cardfive software and magicard rio print
Hi There,
I hope this helps.
Regards,
MC.
Feb 12, 2009 | Magicard Rio Card Printer
Printing problem
Hi JuanU,
Which version of Windows are you running now? Vista?
If it is Vista, you will need to use the newer 'UltraDriver' for the Opera printer (V1.3.0.0 Issue 1).
This can be downloaded from Magicard's web site here;
http://www.ultramagicard.com/fileadmin/inc/support_scripts_en/printers/files/ultradriver_opera__v1.3.0.0_iss1.exe
NOTE!!! This driver will ONLY work with the following operating systems: Windows 2000, XP, Server 2003 and VISTA. If your PC has a different OS from those above DO NOT install this driver!
If you have an 'older' Opera printer which does not have an 'E' in the serial number, you will need to change the 'PRODUCT ID' from 2000 to 2800 before this driver will recognise the printer.
This is quite simple to do. Download and install the Magicard Support Utility Version 3.13 by clicking on this link;
http://www.ultramagicard.com/fileadmin/inc/support_scripts_en/printers/files/msutility_v3.13.exe
Run the Utility, select 'USB' for the comms port.
When the other tabs open up, select 'Statistics / Commands'.
In the 'Quick Command' box type;
PID2800
Then click 'Send'.
Exit the Magicard Support Utility, and unplug the printer's power cable.
Now, install the UltraDriver version 1.3.0.0 Issue 1.
When the driver install has finished, plug the power cable into the printer. The hardware wizard will finish the installation and you will then see the 'Magicard Opera' printer icon in your printers folder.
It should then work fine.
Let me know if you have any problems.
Regards,
MC.
Jul 22, 2008 | Magicard Opera 100 Card Printer
Offline
Hi There,
I think this may be something Win 2K is doing.
However, rather than power cycling the printer, simply removing the USB connection then replacing it should be enough to 'wake it up' (and save on dye film).
Check the power saving settings for your USB Root Hub;(Hardware/Device Manager/USB Controllers/ USB Root Hub/Properties/Power Management). Make sure the 'Allow the computer to turn off this device to save power' option is NOT ticked.
Check also under 'Settings' / 'Printers', right-click on 'Magicard Printer Series', you should NOT see either 'Resume Printing' (printer is paused), or, 'Use Printer Online' (printer is offline).
Also, make sure you have the latest drivers installed. The Rio 2 / Tango 2 driver V6.01 is compatible with the 'older' Rio / Tango printer (even the non 'NP' models). You can download this here;
Make sure though that you select 'update driver files' and NOT 'add a printer' when prompted (restart is required). Port name should be 'NUSB01' when you see the list of available ports.
I hope this helps.
Regards,
MC.
Mar 11, 2008 | Magicard Rio Card Printer
I have error whenever i just select encoding only
Hi There, I presume (from the error number) that you are using LC3 (monochrome) dye film in your printer. This error is normally given when the printer detects LC3 (monochrome) dye film, but is then sent 'Colour' printing data from the driver. If you have 'encode only' selected there should be no printing data sent to the printer at all (number of copies = 0), only the mag stripe information should be sent. I suggest you contact Magicard Technical Support in the UK (I am one of their support engineers). We will need some further information (serial number of the printer, etc). Please also check you have the latest firmware (print the internal test card by pushing the button on the back) and are using the latest driver. All are available for download from: www.magicard.com To contact customer support send an email to: customer_service@ultra.co.uk Advice is free regardless of whether the printer is in warranty or not. With Best Regards, Alan.
Aug 20, 2007 | Magicard Avalon Card Printer
Magicard Alto Card Printer Logo
644 people viewed this question
Top Magicard Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
