Question about Koss KS2503 System
Cd tray won't open
Display shows MSG 04.What is the problem and how do I fix it?
I tried unplugging, but it did not work.
  • 38 Answers
It is Koss brand,you shouldn't expect much from it. You could have an A/V repair guy to fix it for you or buy a better brand like panasonic,denon, or even samsung.
Posted on Feb 04, 2008
How do I open my CD Tray and remove a trapped DVD? The Display shows "Locked", everytime I try to press eject button on the Receiver.
Unplug the machine. Have a look behind the tray flap. there should be a very small hole to push a paperclip or similar into to release the tray.
Mar 08, 2015 | Televison & Video
XDMA6438 CD Receiver
pls. unplug the unit then plug it again, turn power on, eject. just repeat this sequence until the cd tray will open.
Jun 22, 2013 | Dual Xdma6438
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
DVD/CD disc opener won't workGetting
Usually the tray has to be opened and inspected and if lucky it can be realigned--if not parts may be hard to find as they usually do not sell individual parts for the mechanism.
Nov 05, 2012 | Televison & Video
My disc tray won't open the lights turn on and work but the disc tray just won't open. How can I fix this?
You have to check two things.
1. You have to check the tray loading belt in the mechanism. To see the same you should remove the mechanism.because the loading belt is beneath the cd tray. As it is cyberhome it will be very difficult to remove the mechanism for an user. if your capable for doing the same then make try. Because you have to remove the top cover then the back panel, then the mechanism. Take care the mother board is attached to the mechanism.
2. You have to check the cyberhome dvd player will show this type of complaint if the Spindle motor is faulty (oppen or short ). Spindle motor is one on which the cd rotates. It will not cost a lot.
May 05, 2011 | Cyberhome CH-DVD 300 DVD Player
The open/close tray will not open. It reads open then close but does not open. It makes a groaning sound as if it's trying to open but can't. There was no warning of this. The display shows imput L2...
Assuming there is nothing stuck in the tray, the gears over time will wear out and the tray will no longer come out. Another possible cause is a weak motor, either way the tray will have to be replaced in order for it to work properly again.
Oct 27, 2009 | Panasonic DMR-E55 DVD Recorder
Koss KS2503 "MSG 04" problem
I had this MSG 04 problem. Opened the player up. Messed around. Figured out that the 5-disc tray was hanging up a little during the initialization. The issue is that the tray screws into and rotates around a stand-up beam. On the underside of the tray are gear teeth which are spun by a gear on the main unit underneath. The real culprit is the stand-up beam in the very middle. It is too long. The fix is to first try just tightening the middle black screw holding the tray onto the stand-up beam. If this tightens and MSG 04 goes away, you're done. If it does not tighten at all or much at all, then remove the screw (actually a bolt) and using a razor or sharp blade, scrape the top 1/4 millimeter off the stand-up beam. Apply some grease around the beam and on top. Note, you may have to remove the tray to do all this. If so, that is the most tricky part. Carefully lift on the tray on the front side as you rotate it. Try to free a disc circle edge over the top of the front DVD cover and free the tray. To re-set the tray, put it on the stand up beam with the front side of the tray slanted up and slowly rotate while setting it in and down. After re-seating the tray, screw the bolt down but do not tighten all the way. Tighten it enough to allow rotation and enough to rid the msg 04 problem. I shaved my stand-up beam and have never seen a MSG 04 since.
Apr 01, 2006 | Koss KS2503 System
Koss KS2503 System Logo
81 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
