Question about Canon Office Equipment & Supplies
Canon PC740 - Paper Out Sensor
Hi!
The sensor which indicates that the machine is out of paper, has broken. The problem is that I don't know where it was located, so I don't know if I would be able to glue it back on :) (or another workaround).
Anyone who can guide me in the right direction (I only have a user manual, so I don't have the techical information on the machine ... and it's too old to have a real maintenance on it...)
Thanks in advance,
Alain
I had to replace the whole thing -had waranty and noone bother to help me to fix it
it is better for the economy to sell a new product than to bother to fix even a small problem
Posted on May 23, 2009
Printer displays alarm and indicates there is a paper jam. However, there is no paper jammed. What can be the problem?
Could be dirt blocking a sensor, damaged sensor, or paper pieces where the sensor can pick them up.
Mar 03, 2016 | Canon Pixma Mx310 Office All-in-one...
Hi, stationary jam indication with no error code in canon irc3170; why it shows like this. Can enybody help me.
check paper pice in the paper feeding unit and chech p f unit sensor switch may be broken
Nov 20, 2014 | Canon Office Equipment & Supplies
My conon printer mx340 says ducuments in adf error
Hi guys,
This error occurs when paper sensor in ADF = Automatic Document Feeder detects some paper inside paper path. Firs, open ADF access cover and check if some broken paper present inside paper path. If no broken paper found in paper path means paper sensor is faulty and you need got new ADF replacement. Thanks
Source:
MX340 Series Service Manual
Jun 27, 2011 | Canon MX340 AllInOne InkJet Printer
Canon ir400 paper jamming at heater section
just remove the cartridge and remove the paper essay
if you don't know how to remove the cartridge just see the user manual booklet or download user manual from cannon website for proper model printer user manual
Apr 16, 2011 | Office Equipment & Supplies
My printer(canon pixma mp190) keeps telling me that there is a paper jam, but i checked and there is no paper jammed, is it broken?
If i not paper in the printer,you must unzip the printer,the paper sensor is skipped.The paper sensor is under the scanner in the middle of printer.If the sensor id broken you need to replace,if the sensor is skipped try to put in the rigth position.Good luck!!!
Apr 09, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Canon PC 941 copier. Paper jam indicated with no paper.
Can be that sensor of the passing of the paper or was broken off flag, or sensor has wedged in position james, more often such can be in block of the fastening, when paper stuck extract. Try its see, this possible behind do. Good luck
Sep 04, 2009 | Office Equipment & Supplies
Machine thinks there's a paper jam
ok what you have done is when you have pulled the paper jam out you have either still have a small piece of paper over the sensor or you have broken the sensor itself it sounds like the later, most people tend to pull out the paper backwards against the feed rollers and sensors just below the feed rollers and it causes the sensor to fall out or break i have seen this so many times,
canon tech
Apr 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Error 1300 keeps coming up on myh Canon Pixma IP4000 although there's no paper?
Dear pants53,
Code 1300 indicates that paper jam error occurs. First, check whether any broken paper inside the paper path, remove it then press Resume/Cancel button. If problem still persist, means paper sensor error or paper sensor cam is broken. If it so, then I suggest you bring your printer to nearest service center.
Regards,
Nov 08, 2008 | Office Equipment & Supplies
Canon PIXMA ip200
You have a stuck paper sensor.
It can be caused by a bit pf paper still inside the machine, or a foreign object in the paper path, or a bent or broken paper sensor actuator.
If you're willing to take the machine apart, you can check the sensors. If not, contact your local service centre.
Oct 18, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
77 people viewed this question
old marine
old marine
