Question about Alpine PXA-H700 Car Video Player
PXA-H700 optimum set up...
The PXA-H700 is running off my OEM head unit (GM, Onstar, XM, Tuner) wherein the "front 1" RCA inputs are being used (the H700 has room for two sets of front inputs (front 1 and front 2, I assume for the tweets, and the other for the woofers). I am running a set of memphis, 6.5" components with its own crossover in front, and a pair of memphis 5 1/4" components, with xover in the rear. I just can't get the volume I'm looking for. The rear speakers are run from the Bose amp that came in my truck, and are controlled via the OEM tuner (not hooked into the PXA). The way these yahooo's set me up, I need to turn the volume up on the OEM tuner up until the PXA-H700 flashed a 'input level error', then turn down the OEM volume until the warning disappears. The problem, I don't get the volume I am looking for, very soft and unbalanced. Do I need 2 amps for the front (tweets, then 6 1/2" woofs), then another amp for the rear and sub? I currently have a JL audio sub, hooked into the center channel of the PXA-H700, running off the same amp as the fronts) What is the most effective way to set up the PXA-H700? two amps for the front, another for the rear, and a third for the sub? Help!!
  • 6 more comments
  • jsiewert May 23, 2009
    Thank you.  Right now I have the JLAudio HD/600 running the fronts and the sub, bose amp runs the rears (and controlled from the head unit)  How do I leverage my new HD/600 amp the best way?  I am planning an install for the rear amp but get confused over bridging and ohms and all that stuff?  I think I understood your answer, just want to clarify...
    is there anyway to get away from adjusting the head unit volume and bypass the input level problem altogether.  Right now the OEM tuner volume is set to about 25% (this eliminates the "input level error", but I am at volume = 35, on the PXA, and the sound is not enough if I am driving to appreciate.
    Did you say a seperate channel for each speaker?  I like that idea, but have no idea how I would config the amps to run properly.  I am going to have my local shop do this, however, i want to give them specific instructions on what I am looking for, and your response HELPS me.
    I want to take advantage of the two Front inputs on the PXA, front 1 and front 2, to get the most felxibility in tuning my ride...do I need to eliminate the memphis xover althogether?
    Again, thank you for your help...you are saving me!
  • Anonymous May 23, 2009
    yes, the hd/600/4
    Yes, its the HD600/4 Thank you again...
    Yes...its the 600/4
    Checking now...
    I assume you are referring to the MX mode..appreciate your help VERY much...
    Thank you for the drawing, I assume this drawing is for my current set up, without the beneift of an amp to run the rears.  I think i am set up as you indicate in your drawing, so I feel a little better.  Believe it or not, my manual is different than the one you URL'd me...different pgs, THANK you!
    Thank you....
    How do I bypass the bose amp if the back speakers are hooked to it?  Meaning, what do I connect to what?  The rear speaker wires are hooked into the bose, is this just an RCA swap?  where is the bose amp?
    Appreciate your patience with me, you have been very helpful!
  • 15,935 Answers
The way the EQ is hooked up is correct.
You set the factory radio to a set level, then use the volume on the EQ for everyday adjustments.
I believe your problem lies in the amplification.
Your BOSE amplifier was made to run a 4 channel 8ohm stero load.
Low powered - high in sound quality.
You have swapped the factory 8 ohm speakers (15W) for 4 ohm power hungry ones.
Now the amplifier is working harder to produce the same output.
You would be best served eliminating the factory amplifier and getting 1 good 4 or 5 channel amp to power your speakers.
a 4 channel amplifier could be used stereo (left and right) on channels 1 and 2, (2ohm stereo load)
and bridge channels 3 and 4 for your subwoofer.
For a true surround sound - a 5 channel amplifier could run each speaker individually, and the 5th channel is reserved for the subwoofer.
a small dedicated 75wx4 channel amplifier with built in crossover, and level gain controls - would blow your socks off. It is 200x better than the factory 12Watt amplifier. Your ears will love you for it :D
If you need more help - just let me know.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 23, 2009
  • 7 more comments
  • blueextc3221
    blueextc3221 May 23, 2009
    give me a minute, and i'll throw together a quickie diagram for you.
  • blueextc3221
    the JL amplifier is the 600/4 correct??
  • blueextc3221
    BTW - CLICK HERE for your owners manual if you dont have it.
    There is a setting I want you to check on page 27.
    Essentually-it is a LOUD button.
    Set it on Maximum and see if this changes anything.
    I am at my home PC right now and now realize i dont have my normal drafting program.. so im doing a rudimentary MSPaint drawing that is taking forever.
  • blueextc3221
    Sorry - CLICK HERE (forgot to hyperlink)
    ok - here is the cra ppy picture i came up with
    it will give you a good idea of how to utilize your current setup to its fullest potential.
  • blueextc3221
    Coming from the EQ Brain - use the "front" pair of RCAs to the FRONT amp inputs.....
    and the SUB or CENTER RCA to the REAR input on the amplifier.
    Change the crossover on the FRONT output of the amplifier to HP and set the filter slope to 12dB, set the filter frequency to 120 and set the gain adjustment properly.
    Change the crossover of REAR to LP, set the frequency to 80hz and set the gain properly.
  • blueextc3221
    with a dedicated amplifier - you should have more than enough sound.
    There must be a gain not set properly, or a setting in the EQ that is wrong.
    In your initial post, you hadn't mentioned the JL amp - so your setup sounds good - even with the factory amp running the rears (as they are just for fill anyway)
    But powering them the same as the fronts will have a positive effect on the overall loudness as well.
    You will get 150W @ 2ohm shared by the speakers- per side- (75w each) as opposed to the 12W your factory amplifier is supplying.
    Hope this helps explain better.
    Thanks for using FixYa!!
  • blueextc3221
    no - the drawing is the way you SHOULD have the system set up... eliminating the factory amplifier and using the amplifier you have to its fullest potential
  • blueextc3221
    Channel 1 for the left side of vehicle
    Channel 2 for right side
    3&4 bridged to sub
  • blueextc3221
    The factory amp is usually under the dash on the passenger side or in the kick panel (you havent indicated the year or model of your truck)
    To bypass - simply unplug the output side going to your speakers and tap into the correct speaker wires.
    Your local shop will have no problems with this.
ONSTAR INSTALLED IN A hONDA crv 2004
No, OnStar is a GM only product. OnStar is a factory-installed option and cannot be installed by a dealer or retailer, so you must do one of the following: 1) Purchase a GM vehicle with OnStar 2) Own a GM vehicle with OnStar. Acura contracted with GM for a few years, OnStar was in the RL. I never heard of this in any other Honda products. ...
CONTINUE READING No, OnStar is a GM only product.
2) Own a GM vehicle with OnStar No, OnStar is a GM only product. <br /><br /> OnStar is a factory-installed option and cannot be installed by a dealer or retailer, so you must do one of the following: <br /><br /> 1) Purchase a GM vehicle with OnStar <br /> 2) Own a GM vehicle with OnStar Minor edit? Save Cancel 4 people
Aug 26, 2014 | 2004 Honda CR-V
How hook amp up to a oem integration SNI-15 line output convertor
The amp needs an RCA input to communicate with the head unit. SOLDER the wires that come out of the head unit for the front speakers to the SNI-15, making sure that the polarity and right/left is correct. Do this for the front and rear speakers if you have a 4 channel amp. Cut the wires if you add new speakers and run the new wire from the speakers or sub box directly to the amp, or skin back the wire insulation and tap on if you use the factory speakers :( then plug your RCA cable from the SNI-15 to the input side of the amp. Don't forget that most new cars have their own amp so you might have to locate it and bypass the speakers wires around it. Don't make a mess in case you have to put everything back to factory for resale. You can avoid all this by installing a new/modern head unit with built in RCA outputs for front, rear, and sub woofer. I hope this helps. Ray
Apr 23, 2014 | Car Audio & Video
W__How do i wire two pioneer GM-D9500F amps i only have two rca outputs on head unit one sub output that is being used with a D class mono amp for sub the other rca to one pioneer GM-D9500F amp but i have...
Hi, you can split the preamp RCAs with Ys available everywhere. The amp input impedance shouldn't cause much load on the head unit. Let us know if you have more questions, and thanks for using FixYa.
Jan 18, 2011 | Car Audio & Video
I have two 12 inch rockford p1 punches powered by an 800 watt sony explode amp (2 Channel) and i want to install another 15 inch kicker with a 1200 watt amp not sure the model, i got it from a friend and...
I have a similar setup & I just run the second amp straight off the other amp by running positive & remote wires directly from 1 amps positive & remote inputs to the others amps inputs. But my head unit has RCA inputs, (sub in & front & rear inputs) so from my 4 channel amp I run 2 6 inch alpine S's to the front to the front RCA inputs of the head unit, & 2 Pioneer 440w 6x9 inch speakers to the rear inputs. & my 800w 12 inch sub from my 2 channel amp to the sub woofer inputs on the head unit. Has blown my eardrums for nearly 12 months now great stuff! Hope this has helped
Mar 12, 2010 | Sony Car Audio & Video
How do you connect an amplifier to factory stereo?
crutchfield.com has a complete list of speaker sizes. Most car amps now have connections for RCA inputs and speaker-level too, so you can probably use the existing head unit: most OEM head units do NOT have RCA outputs.
Jul 30, 2009 | 2003 Mini Cooper
Sony xplod amp xm-1652z high level input connection
First off, if you're using RCA preamp connections from the head unit to the amp, you don't need to put anything into the high level input connector. But if your head unit doesn't have RCA preamp outputs, then connect the front left to the white (+) and white/black stripped (-) wires and the front right to the grey (+) and grey/black stripped (-) wires. There is no need to connect the rear speaker outputs of the head unit to the high level input of the amp.
Apr 17, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Wiring my tuner-DEH-1800 to Amp GM-5300-T into my 4 speaker system.
In most head units as in your case the Pioneer DEH-1800, there would be 2 RCA female jacks at the rear of the unit. These are your OUTPUTs.
While in most amps including your GM-5300-T, there would similar RCA jacks which would be your INPUTs.
You need to connect the output to the input using an audio cable terminated at both ends with RCA plugs. Further you need to connect the remote trigger on from the head unit to the remote/external amp to switch it on.
A more comprehensive connection diagram is available at page 6 of the GM-5300T Manual which may be downloaded from here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Pioneer DEH-1800 CD Player
XM RADIO PROGRAMMING
For the Ilo CA3000v, all you need is an XM direct tuner box, Model XMD1000, the cable that came with the Ilo radio, and an RCA cable to connect the two. The RCA jacks and the 8-pin DIN jack on the back of the ILO CA3000v are exclusively used for XM signal translation. You will, of course, need a subscription to XM Satellite radio, but the items listed above cover the extent of the hardware you'll require. The XMD1000 comes with the antenna as well, so no need to worry about that, and all XM features are controlled from the head unit itself
Dec 11, 2006 | iLO CA3000V CD Player
3/4 channel sony amp
Yep! It's called a Y-Splitter. They make different variations of them: http://www.computerplug.com/img/cables/CRCA-YFFF.jpg https://www.wiredco.com/catalog/images/PYTHONRCAY.jpg http://4netconnex.com/images/products/8-2521.jpg
Aug 14, 2006 | Sony Xplod XM-554ZR Car Audio Amplifier
Alpine PXA-H700 Car Video Player Logo
426 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
