Question about Bosch 1034VSR 8 Amp 1/2 Inch Drill
Intermitent start mostof the time it doesn't start at all
I have a 1034 vsr drill that has developed a problem. It starts now and then but most of the time nothing. could it be the switch ? If not is it worth fixing ? Thanks for your input
    Brigadier General:
  • 5,158 Answers
Sounds like the brushes have worn out .... replacing them will sometimes fix the issue.... you may have to have the rotator turned (machined) ....
Posted on May 23, 2009
Problem with the Dewalt 3/8"VSR
My solution when the other mentioned ideas didn't work was this: I removed the 7 Torx #20 screws ( a common screw driver will work as well) and removed the housing half to expose the shaft. The chuck shaft bearings and gear lifts out as one assembly. Directly behind the chuck there is a half inch section of shaft exposed. I mounted a vise grip on the shaft (won't hurt it) and clamped the affair in a bench vise. With a 5/16" allen wrench mounted in the chuck and using a mallet I spun the chuck off with a solid smack counter clockwise . Very simple and easy .
Aug 29, 2011 | Dewalt 3/8"VSR 6AMP CORDED KY DEWALT DRILL...
Need to replace the chuck on a Bosch 1194 VSR Model number 0 601 194 739
open the jaws of the chuck up all the way. There is a retaining screw at the bottom ( under where the drill bit would go). this screw is reverse thread. once the screw is out, get a 3/8 inch allen wrench. chuck the short end into the drill chuck. set the drill on a workbench with the chuck hanging off the edge a bit. Hit down on the allen wrench with a hammer ( counter clockwise) and the chuck will unscrew normal thread.
Oct 21, 2010 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
Dewalt cordless drill dc988- drill motor works intermitantly when trigger is pulled. Works a little better as it warms up. Im thinking vsr switch, brushes, or motor/armature. please help...
Test the brushes by catching it in a stalled condition when you have it triggered, then rotate it slightly. If it takes off suspect the brushes or a dead segment on the comutator.
If it doesn't respond to this, then consider the VSR trigger... open it and test by bypassing it when in stalled condition...
Mar 20, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
I have vsr drill 18v cordless.what type of adaptor do i need to use
u should find 18v DC adaptor..
smaller ampere output can result a longer charging time..
that's all
Jul 31, 2009 | Drills
How do you load screws in Dewalt DW272WT VSR
You definitely need a hex-bottomed screwdriver bit. Please rate me
Jun 09, 2009 | Dewalt Drills
I have an older model of the Black & Decker 0-1200 VSR drill.
Check out www.2helpU.com this is the Black & Decker After Sales Service site which has all diagrams for most tools along with manuals
Mar 12, 2009 | Black & Decker Drills
Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Jan 26, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Bosch 1034VSR 8 Amp 1/2 Inch Drill Logo
120 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
