Question about Panasonic PT-47WX49 47" Rear Projection Television
OBCk followed by varying numbers is displayed in the upper left corner. What does this mean
Obck with varying numbers behind it is displayed in the upper left corner. what does this mean?
  • lencamp2 May 26, 2009
    CHKOBE7A48454509
  • Panasonic Master
  • 8,617 Answers
Thats on screen error whats the numbers that follow?
Posted on May 24, 2009
  • Sonny Berry
    Sonny Berry May 26, 2009
    Your in the service man mode. On the front of the set you will see the action button and the power button. Press both of those buttons in together for at least 5 seconds and that should allow the set to exit the service mode. Then power up the set and it should be gone.
Ti 30x IIS displays memory cleared and will not do
Not sure but try
  • Press the "ON/AC" button to turn the TI-30Xa on. If the top-left corner of the display reads either "M1," "M2" or "M3," a number is stored in the corresponding memory.
  • 2 Press "0," "STO" and "1" if the number in the corner reads "M1." The upper-left corner should no longer say "M1."
  • 3 Press "0," "STO" and "2" to clear the "M2" memory. Pressing "0," "STO" and "3" clears the number stored in "M3" memory.
  • Read more : http://www.ehow.com/how_8623666_clear-memory-ti30xa.html
    Oct 14, 2014 | Office Equipment & Supplies
    Where is the model number on maytag quiet plus ii washer
    Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
    Jun 13, 2013 | Washing Machines
    I have a LG model LFX25960ST refrigerator with an error code of FF. I know this means the freezer fan, but is that one of the fans located in the freezer? When looked up online, neither of those two fans...
    yes, its located on the freezer; behind the rear wall. yours has 2 fans; one for the ice cube room (upper left corner) and the fridge/freezer motor (in middle) behind rear freezer wall. this is the motor you will need. the part number should be on it.
    May 10, 2011 | LG LFX25960ST Stainless Steel French Door...
    Need diagram 2001 vw new beetle fuse panel. When I bought it did not have panel cover........thanks! problem with washer pump book says #1 10 amp small fuse and #24 20 amp no where on fuse panel says #'s
    The #1 fuse is in the upper left corner of the fuse panel, actually its the top fuse in the third row down, but row No. 1 and No. 2 do not have any fuses in the upper left corner. There are a total of 23 fuses in the upper most section. Fuse #24 is the first fuse in the lower section of fuses (upper left corner of that section as well.
    The block diagram for the fuse panel is also contained in Section 3.2 of your Owner's Manual. The fuses are numbered in each section from top to bottom starting in the upper left. Fuses 1 thru 23 in the top section, fuses 24 thru 44 in the bottom section which consists of three columns.
    Oct 28, 2010 | 2001 Volkswagen Beetle
    Where can I find the model number on my kenmore elite washer?
    TOP LOADERS
    Look at following areas for the model number:
    * Rear Center Of Lid Well
    * Left Upper Back On Base Cabinet
    * Back Top Control Panel
    * Right Rear Corner Of Washer Top Lid
    * Open Lower Left Front Base
    FRONT LOADERS
    * Rear Center Of Door Well
    * Right Rear Corner Of Washer Door
    Oct 26, 2009 | Kenmore Washing Machines
    Water in LCD display
    Once you get a dead pixel (black dots), there is no way to repair that part of the screen
    Sep 20, 2009 | Computers & Internet
    Where do I find the serial number for the Kenmore Ultra wash III dishwasher
    * On Right Hand Side Of Upper
    * Front Tub Or Door Jam
    * On Flange Behind Dishwasher Door
    * Behind Latch Strike
    * Upper Left Corner Of Frame
    Jul 19, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
    Lines on upper left corner, inside of screen
    its problem with the display cable (not the one you connect to your pc)
    open the lcd display and look for a cable that is attached to the front glass display. check whether it is dameged.. it cannot be replaced
    you need to replace the whole display that would be better. and cost effective
    Jun 11, 2009 | Princeton Digital VL1918 Monitor
    Saeco Primea Ring - no milk - just steam
    Hello!!
    Okay! Looks like many of you out there has the same problem, whit the milk temerature (not me i never had).
    But there is a service menu on primea touch plus series.
    Im from Sweden but i will try my best to explain how to enter the menu. First of all !!MUST!! write down off parameters before changing any thing!!!! It is possible to set the grinder to grin more coffie for each cup. I think the factory setting is 85 Aroma impulse. It is possible to change that for you type of coffie beans that you use, i will diff from bean to bean.
    Okay, to enter the menus you have to turn you machines off.
    Now turn it on !!!!!EXACTLY!!!!! when the display lights up press your display in the following order ALWAYS IN THE CORNERS (you will not see any icons were you have to touch on you display) RIGHT LOWER CORNER, LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER.
    To enter the second service menu, do as i explained before but use this "CODE" instead. LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER, RIGHT LOWER CORNER. This is it! Hope i could help you! Remeber to write down before doing any changes! DO NOT ERASE ANY FAULT CODES YOU SERVICE CENTER WILL FIND THAT INFORMATION VERY IMPORTANT!!!!!
    Dont say that it didnt work, it will it´s a huge matter of timing!!!! IT WILL WORK!!!!
    Let me know some results please!!
    Apr 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
    How to clear all information from screen
    screen has (m3)and (m1) in upper left corner, have not been able to totally clear screen.
    Apr 10, 2007 | Texas Instruments TI-30XA Calculator
    Panasonic PT-47WX49 47" Rear Projection Television Logo
    52 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
