Washing Machines Logo
A
Anonymous Posted on Jan 05, 2014
White knight keeps blowing eletricity sockets down stairs pnly when i plug it in changed fuse in plug still the same
john
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Washing Mach... Expert 517 Answers
  • Posted on Aug 17, 2014
 john
Level 2:
Prodigy:
Answers
517
Questions
Helped
134175
Points
901
You have to check the heater and the motor first as one off these may by need to be changed or repaired
Trying to find the problem to why my park light fuse keeps blowing?
You are replacing parts but you should be focusing on wiring. you will need to physically check all the wiring for the rear tail lights and the front park lights for shorts to ground. you can also unplug all of the bulb sockets, replace the fuse, and see if it blows. if it does than it is in the wiring. If it does not than plug the sockets back in one at a time until the fuse blows, then inspect or replace that socket.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Headlight keeps blowing
hi,
use the process of elimination, disconnect both headlights at the bulb and put another fuse in it and see if it blows. if the fuse blows without the headlights plugged in then its the wiring to the bulbs. if the fuse doesn't blow while the headlights aren't plugged in try plugging the lights in one at a time to see which headlight or socket is shorted. possibly corrosion at body to ground connections near the headlights, you may not see the corrosion, remove the ground wires and sand those ground wires down..
Keeps tripping out my down stairs sockets.checked the wires going to the machine and the plug.all seem fine.? Please help
IS BEARINGS OK IN DRUM IF NOT THE DRUM HAS GONE THROUGH HEATING ELEMENT ...TURN DRUM BY HAND IT SHOULD BE SMOOTH .. OTHERWISE CHANGE HEATING ELEMENT.
1helpful
My tail lights are not working, it keeps blowing my fuse.
1.Unplug your taillights at the sockets and the front running lights from sockets.
2. put in new fuse after unplugging taillights.
3 turn on taillights if fuse blows then the wiring is grounding out somewhere between the switch, fuse panel, and rear and or front parking lights.
4.If fuse does not blow then plug in one socket at a time keep rechecking fuse. when the fuse blows after plugging in a certain socket suspect that one to be bad and replace.
1helpful
White knight dryer wk767 (Crosslee) blows fuse when turned on
Probably a problem with the heater element (if mineral insulated metal sheath type), or fluff on wire heater coils if that kind. This is behind the back cover.
Feb 27, 2010 • Dryers
2helpful
2answers
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
1helpful
White Knight 44AW electrics problem
You may have a short in the system, make sure your breaker is rated high enough to support the dryer
1helpful
2answers
White knight 44aw not spinning and no heat
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 26, 2009 • Dryers
Energy Knight AC Blowing Fuses
My Energy Knight mini split air conditioner does not come on at all, no sound no lights nothing. I have changed the batteries with no luck. please help
3helpful
Radio fuse keeps blowing
make sure nothing in cig lighter socket..coins,etc..if nothing present,unplug cig lighter socket and replace fuse..if fuse doesn't blow,it's the socket causing fault..if it does,unplug radio,plug cig lighter back in and replace fuse..if fuse doesn't blow,radio is cause of fault..if it does,then ther is short in wiring
Top Washing Machines Experts
john h
