Question about Toshiba 50HDX82 50" Rear Projection Television
The projection lenses vertical and horizontal lines are off level
I have a 50" Toshiba Rear Projection Cinema Series, the lenses are not properly aligned. The vertical and horizontal are not leveled. Any idea on how to adjust them? RAGS
  • Toshiba Master
  • 8,617 Answers
Your convergence ICs have failed. replace both STK392-110 ICs
Posted on May 24, 2009
Toshiba Rear projection 65" cinema series
You need to replace or have the convergennce IC's replaced. This is not a very hard job to do, but will take some soldering skills. Good Luck
Oct 21, 2007 | Toshiba 50A61 50" Rear Projection...
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    The picture is all horizontal. The audio is fine. what cases this and can the part be replaced easily by myself?
    jnagle,
    By horizontal I will assume that you mean there is no vertical drive and you just have a line across the screen. If this is the case then I have a tip at http://www.fixya.com/support/r7887362-crt_projection_tv_lost_vertical_drive which should help resolve your problem.
    Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
    hardrocko
    Jan 19, 2011 | Toshiba 50H72 50" Rear Projection...
    Distored picture
    Well, if your horizontal is off frequency and you have diagonal lines then there's no need to look at the Horiz Output Transistor or the Vertical section. You will have to use your scope to check the oscillator freq. and go from there.
    Jan 14, 2010 | Toshiba 50H82 50" Rear Projection...
    The screen on my toshiba 50h12 is messed up. its as though the horizontal is not matching up...how can i fix this myself?
    It sounds convergence out chips got bad in your Tv and causing problem. Replace convergence out ICs in TV if you are familiar with electronic stuff repair.
    Required parts are available in Part Store.
    Dec 24, 2009 | Toshiba 50H81 50" Rear Projection...
    Our tv is 10 years old toshiba cinema series it has blue and red
    It will be 11 years next month that I've had my Toshiba 55H55 Cinema Series and have the same problem every now and then, if you haven't already done so, go to the picture settings and scrolling down to conversion and it will take you through 3 steps of adjustments,there is a white cross in the middle of the screen line up the red first and then the blue, it will then take you to a screen with numbers, ID the clearest number and exit out, you should have a clear picture again. I hope this helps.
    Jan 06, 2009 | Toshiba 50H81 50" Rear Projection...
    Toshiba Cimema Series 55''
    most probably the convergence is going bad, enter the menu and realign the converg. match the red to green and the blue to green
    Aug 17, 2008 | Toshiba TZ50V51 50" Rear Projection...
    Pioneer projection TV vertical lines on screen
    do you have full picture and did this set have any faults before this,possible image burn on crts.from previous horizontal fault.
    Aug 17, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
    Toshiba 50HDX82 50" Rear Projection Television Logo
    170 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
