I have a GE model# WHDSR209D5WW top loading washer. It looks like I have a missing part or bushing because whenever I use the washer the tub base keeps knocking the frame of the washer.
  • nsbsin1 May 23, 2009
    no they are both in tact
  • steve
    steve May 11, 2010
    Remove the front panel and check the shock absorber rods on the corners. One or more may have come loose.
    Genius:
  • 1,122 Answers
If you remove the front (use a putty knife in the seam)you will see 4 rods with shocks on them,check them,also the top of the tub has 4 rubber straps connected to the tub and frame check also,let me know what you find-mike
Posted on May 24, 2009
GE top load profile washer won't spin. It starts
The tub hangs on 4 support rods. Lateral movement is kept in check with 4 bungy cords bolted to the top of the tub. If that washer is not level the tub will hang to one side and the fancy controls will declare an error. Make sure all your rods are good (they drag the base of the machine when worn out and make a heck of a racket) and the bungys are not stretched and the machine is level.
Aug 04, 2012 | Washing Machines
Ge model wbse2090a washer over fills in the rinse cycle
Clogged pressure switch hose at the tub on left front side of tub pull off and use a small screwdriver or a pipe cleaner to clean.
Feb 22, 2010 | GE WBSE2090A Top Load Washer
Ge profile washing machine
There are four suspension rods that the tub hangs on. When the washer is agitating the tub will rock back and forth and the rods will move back and froth as well. To fix this noise, lift up in each rod and put some lubricant in the cup that the rods fit into at the top of the washer.
Note that it is best if you use a lithium-based lubricant rather than silicone based lubricant.
Feb 18, 2010 | GE WBSR3140DW Top Load Washer
I have a GE Select Top loading wash machine that is making alot of noise during the spin cycle. 99/2000 model
If it sounds like a jet plane taking off, a grinding noise, it is the bearing. This is pretty difficult to replace. If you do attempt it, you MUST replace the inner tub seal. This is leaking onto the bearing, causing it to go bad.
Jan 18, 2010 | GE WBSR3140DW Top Load Washer
My washer won't spin or aggitate. I have a GE
Check the belt and clutch in the front under the lid run a butter knife under the lid and pop the front off and take a look.Have a great Thanksgiving.
Nov 25, 2009 | General Electric WHDSR209DWW Top Load...
Washing machine won't spin or aggatate
We had the same problem and it was really easy to fix. On the dial for the load size, turn it all the way to the right to "reset" and then check to see if it resolves the problem. It did with our washer same model and problem. Best wishes.... Doug
Jun 08, 2009 | GE Washing Machines
GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Feb 26, 2009 | GE WPRB9220D Top Load Washer
My GE washer wont stop filling with water or go to the wash cycle. my GE top load washer water will not stop and leaks out, overflows. model #GCXRPO9ODAWW.
You have a problem with the water level switch.  It is located in the base of the machine below the tub.  Replace it and you'll be fine.
Nov 20, 2008 | Washing Machines
GE WBXR2060V1WW leak_transmission shaft and tub
The tub seal is leaking, often this damages the transmission. A new tub seal comes with the transmission this page should help http://www.appliance-repair-it.com/GE-washer-disassembly.html
Nov 12, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
