I have a GE dishwasher where the water at the bottom is not draining fully. I have checked the strainer, nothing seems to be clogged there. Please suggest a solution.
Same Problem
Sep 26, 2008
-   Our GE dishwasher has been working fine. Just lately it goes thru all the cycles OK, but when it's all done, it still has water left in the bottom of the dishwasher. Apparently it is draining, but not completely.
-   Sammmyboy
Jun 24, 2008
-   our dishwasher will not drain out occasionally. The repair man came and "touched" something underneath it and it began working again. He would not tell us what he did. Literally he took 5 to 10 minutes. . . . Any suggestions?-   banderson1
Apr 10, 2008
-   My dish washer wont drain either I took all the hoses off they were not clogged at all, no debris anywhere....any suggestions for next step..To even get a repair man to show up here is $75...then the parts...can get a new one for like $250....Any suggestions???-   trocthree
Apr 04, 2008
-   MY DISHWASHER WILL NOT DRAIN-   Vsam0777
Mar 22, 2008
-   my dishwasher does not empty all of the water sometimes a little sometimes allot it must be draining but when it is done there is water on bottom not drained out it cleans and cycles normal except for this-   Guest
If you take the toe panels off and look at the motor you will see the discharge anti-siphon tube there with the drain hose attached. That tube is the discharge major restriction point. Be careful not to destroy the anti-siphon valve, by pulling the bale, remove it, a flapper valve. If you can't see through the tube you have found the problem. Punch a screwdriver into it to dislodge the crap and clean it up. Put the anti-siphon valve back in as found and check it out. Be careful, when you remove the tube , water will come out of the pump assembly. If you remove the hose be sure to watch for water there also.
I was having the same problem with water sitting at the bottom of my dish washer. I had recently installed a new garbage disposal when the problem started. You need to make sure that you knock out the inlet valve where the disposal drain line hooks up. If you have never hooked up a washer to your disposal, this piece will be in place. Stick a flat head screwdriver in where the drain hooks up and hit it with a hammer and the small plastic circle will pop out. The washer does not use any water when that is blocked and therefore will leave the old water to turn rancid...I hope this helps!
i tried all the other stuff then took the hose off of the pump there was a piece of plastic from a wheel that had broken over a year before jamming the pump it was not that hard to do
Our Frigidaire has not been draining completely. After I fussed around looking for answers, my wife read the manual and fixed it. She completely cleaned the inside out and the vent on the sink was really dirty and plugged. Now it works fine.
Frigidaire 24 in. PLD2855 Built-in Dishwasherfinal rinse water not draining. Wash water is draining....
(More)
Frigidaire 24 in. PLD2855 Built-in Dishwasherfinal rinse water not draining. Wash water is draining. The pump is free of clogs and blockage
There is any water entering the dishwasher (has always worked before) and all other water supply...
(More)
There is any water entering the dishwasher (has always worked before) and all other water supply coming off main same pipe is working (no leaking water). Any thoughts or suggestions?
my dishwasher goes through all the cycles and i can see that it drains during the cycles by looking...
(More)
MY DISHWASHER GOES THROUGH ALL THE CYCLES AND I CAN SEE THAT IT DRAINS DURING THE CYCLES BY LOOKING INTO THE GARBAGE DISPOSAL. HAVE CLEANED THE SCREEN AND TOOK THE HOSE ALOOSE FROM GARBAGE DISPOSAL AND IT IS NOT CLOGGED. THE SINK DRAIN PROPERLY TOO. BUT AT THE END OF RUNNING, THERE IS STILL WATER IN THE BOTTOM OF THE DISHWASHER. WHAT IS WRONG WITH IT?
