NO signal input, for NO reason!
I think that this problem is related to a previous issue that I was trying the resolve.
The original issue was that only one of my CD drives was working correctly(ish), the other one kept messing around. I decided that switching the two around might give some hints to what the problem might be however once I did that I got ''no signal input'' on my monitor. I then returned the CD drives to the original possition and tried again, the same problem reoccurred.
- I then tried using a different monitor and cable, that did not work.
- I check that nothing had been dislodged
- I tried disconnecting the CD drives and running without them, that did not work either.
nothing worked. At a guess I would say that I must have damaged the montherboard when removing the cable for the monitor however how can I check this? I can not see any physical damage.
There are no error beeps and everything else seems to be running normally, I can hear the fan and so on. Does anyone have any suggestion on what could be the next step (other than buying a new motherboard).
  • Lee Henderson May 26, 2009
    Ok,
    I have tried to reset the BIOS (god only knows why) like was suggested in some of the sites that I looked at. This has not fixed the problem and now when I turn it on the fans still work however the lights on the CD drives no longer light up. I am also no longer able to turn the computer off my holding down the power button.
    Oooops!!! School boy error...
    Apparently resetting the BIOS did in fact fix the problem. I had to remove one of the power cables in order to reach the jumpers and forgot to plug it back in *blush*.
    I am still getting a single error beep though (but I think I had that before), other than that it is running fine.
    President:
  • 1,996 Answers
Check the linked conversations here and here, here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 23, 2009
  • efs_perpends
    efs_perpends May 26, 2009
    Here's a link to some articles that will help you diagnose the beep code. You'll need to know the type of bios or motherboard manufacturer you have to look up the appropriate error code.
The tv screen on my u-verse tv shows no signal
Hi!
No signal issues are mostly resolve by checking the TV input settings.
You can follow the ff. steps:
1. Using the original TV remote control, look for a button labeled "tv / video", "input" or "source"
2. Select each of the available input until you get the Uverse picture or if you can check the type of cable that you are using to connect the TV and receiver, it'll help you to easily select the input settings. example HDMI cable
I hope this helps you and please don't forget to rate me.
Thank you. :)
Aug 18, 2014 | AT&T Televison & Video
What should I do because it says no signal input
Sounds like your video card or monitor is bad. Most likely it's the video card because if it was the monitor the No Signal Input could not appear on the screen. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed Monitor displays ok without a problem then your original monitor is bad. If the Borrowed monitor has the same issue of No Input Signal as your original monitor, then your video card inside the computer is bad.
May 30, 2012 | Biostar MCP6PB M2+ Motherboard
Picture to large for the tv screen, some of the picture goes off the screen
Some sets and some boxes used for signal have adjustments for width and height of picture---another possible reason is set has a problem.
If it does not have this issue with a DVD etc hooked via rear inputs it is a signal related issue.
May 01, 2012 | Televison & Video
Hi i have a TC-L37X1 panasonic tv and im having issues with the hdmi inputs. only when i use those inputs i get distortion and wierd effects on the screen. i tried a firmware update but it didnt resolve my...
This happens because either the HDMI cables are defective or the signal path goes thru a device that isn't fully HDCP compatible - the system thinks you are trying to copy the movie or whatever without authorisation+ you're a pirate.
Aug 17, 2010 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
No signal from coax input on 32" lcd
Hi
Thanks for using FixYa. Due to two things that will cause the No Signal message to come up are – no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No Signal!
If this doesn’t resolve your issue then the problem may be with the processor failing and it is causing a random read of the EPROM to display the No Signal message.
I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts.
Try using Component cables if this doesn’t make a difference. After using components cables your issue will be resolved.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 16, 2009 | Insignia IS-LCDTV32 32 in. Television
I have a 32" panasonic which is less than a month and hve issues with pixling
This normally causes by weak signal. To make sure your TV has no problem, you have to try all inputs. If all inputs have the same problem. You may think of the main board was defected.
Additional, you can play DVD player to see if the problem there.
Aug 18, 2009 | Panasonic TC-32LX60 32 in. LCD Television
I need 4 digit ''input''code a 1990 VS-4501R big screen mitsubishi.
If you have the original remote or at least one with a QV button on your remote it is easy.
When prompted for the code, Just hold down the "QV" and the number 9 together for a bit.
That will unlock the set.
I would then go the the main menu and unlock the set from the menu. Use the "QV" and 9 to get in and turn off the password.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Aug 07, 2009 | Televison & Video
My surfboard sb4200 just keeps disconnecting from the internet.my OS is vista ultimate.
Most likely your incoming cable signal is weak. If you call your cable company, the on call support tech can sometimes resolve the issue from their end.
If not they can send a technician to your house to measure the signal strength. The tech should first measure the signal strength before it comes into your residence and then again at the input to your cable modem.
The surfboard also has an internal web interface that provides a good deal of information relating to your signal strength and other diagnostic information.
I'm not sure about yours, but the internal ip address of my surfboard web interface is 192.168.100.1
Regardless though, you still need to get your ISP involved to resolve the issue.
Jul 10, 2009 | Arris SURFboard SB4200 Modem
Unusable Signal
Hello Mike:
The issue that you are having is with your small signal board and it needs to be replaced, it sounds like the microprocessor on that board is getting locked up.
Aug 19, 2008 | RCA L42WD22 42 in. LCD Television
Westinghouse ltv 32w4 hdc 32.02 in. hdtv lcd tv / dvd combo
My 42" Westinghouse HDMI inputs just stopped working. I thought it was the TW Explorer 4250HDC issue so I got a new one from TW. Still said no signal from HDMI. So, I shut the TV down and pulled the power cord out of the back. I waited a few seconds and reconnected the pwr cord. The TV "re-booted" so to say and now the HDMI inputs work. I think TVTEK has the right idea that it is firmware/software related. In the mean time, you might want to give that a try.
May 25, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
