Question about Ice-O-Matic ICEU220HA Undercounter Ice Machine
Ice-o-matic wont' drain water from bin
I have a new purge valve installed a year ago so I don't think that is the problem. I am not sure why the water wont' drain from the ice bin. The machine makes great ice.
  • 1 more comment
  • intmedhead May 23, 2009
    it is an ICEU220 undercounter mount
  • steve
    steve May 11, 2010
    There is a manual purge switch on this model. Does the valve energize when you push it?
  • steve
    steve May 11, 2010
    Apply line voltage to the purge valve and see if it works. If it does work you have a relay coil not energizing the purge valve.
    Your model may incorporate the purge relay in a solid state board.
    I would need a model number to know for sure.
The purge valve empties the tray... the bin just drains with gravity... If you bin isn't draining... it must be clogged somewhere.
Posted on May 30, 2009
  • lipr May 30, 2009
    try taking a hose and holding it over the drain hole to flush out any possible clog. : )
Can purge valve affect making of ice
Yes if it has a bypass leak it will pump water out at same time as pumping over evap. try pinching off the dump valve hose just after starting a freeze cycle and see if it makes a full sheet
Apr 02, 2014 | Ice O Matic Complete Units Ice0250fa Ice...
Ice machine making cloudy ice
ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
Jan 23, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Mine alway,s freeze up and well stop working
Cleaning should be performed every 6 months. 1. Harvest problems may occur if the following procedures are not preformed every 6 months. 2. Remove the ice machine front panel. 3. Make sure all the ice is off the evaporator. If ice is being made, Wait for cycle completion, then turn the machine "off" at the ICE/OFF/WASH selector switch. 4. Remove or melt all ice in the storage bin. 5. Add recommended amount of NICKEL SAFE ice machine cleaner to the water through according to label instructions on the container. 6. Initiate the wash cycle at the ICE/OFF/WASH switch by placing the switch in the WASH position. Allow the cleaner to circulate for approximately 15 minutes to remove mineral deposits. 7. Depress the PURGE switch and hold until the ice machine cleaner has been flushed down the drain and diluted by fresh incoming water about 15 min. 8. Terminate the wash cycle at the ICE/OFF/WASH switch by placing the switch in the "OFF" position. Remove the splash curtain and inspect the evaporator and water Water spillway to assure all mineral residue has been removed. 9. If necessary, Wipe the evaporator, spillway and other water transport surfaces with a clean soft cloth to remove any remaining residue. If necessary, remove the water distribution tube, disassemble and clean with a bottle brush, Reassemble all components and repeat steps 2 through 7 as required to remove residue. 10. Turn off ice machine water supply and clean the water trough thoroughly to remove all scale or slim build - up. If necessary, remove the water trough to reach all splash areas and float.11. Prepare 11/2 to 2 gallons of approved ( EPA/FDA) sodium hypochloride food grade sanitizer to form a solution with 100 to 200 ppm free chlorine yield. 12. Add enough sanitizer solution to fill the water trough to overflowing and place the ICE/OFF/WASH switch to the WASH position and allow circulation to occur for 10 minutes and inspect all disassembled fittings for leaks. During this time ,Wipe down all other ice machine splash areas,Plus the interior surfaces of the bin, deflector and door with the remaining sanitizing solution. Inspect to insure that all functional parts,fasteners,thermostat bulbs (If used ), etc.are in place. 13. Depress the purge switch and hold until sanitizer has been flushed down the drain. Turn ON the ice machine water supply and continue to purge to the diluted sanitizing solution for another 1 to 2 minutes. 14. Place the ICE/OFF/WASH switch to the "ICE" position and replace the front panel. 15. DISCARD THE FIRST TWO ICE HARVESTS. If this dose not help your problem let me know and we can solve it.
Dec 15, 2012 | Ice-O-Matic ICEU220HA Undercounter Ice...
Scotsman model 806 ice machine bin full ight is on and no ice in bin,replaced bin sensor a month ago i cant think of anything else it could be replaced the board last month to and the water inlet valve...
Is there anything hanging down in the beam of the sensors? check sensor connections at the controller make sure there is no moister in it and are making good connections. is your water real hard a lot of minerals dirtying up the eyes. if all of this is clear and sensors are good then nothing else but the control board.
Oct 02, 2012 | Scotsman Ice Machine, Cuber, 1930 lb....
Not making enough ice
What is the ambient air temperature in the location it is installed??
Aug 27, 2012 | Ice-O-Matic Ice o matic Iceu220a Cube Ice...
Water keeps overflowing over the ice making coils
Do you mean that it is overflowing the sump tray into the bin? If so there are two things to check. First make sure the unit is level. Second their is a simple water float valve much like an old toilet float that keeps the sump full. Turn the machine off and make sure that the float will stop the water flow 100% when the sump water level is just over the bottom of the water pump impeller. If the float will not stop the water flow either the water pressure is too high or the float valve is bad and has to be replaced. In general water pressure should be between 20-40 psi.
Dec 18, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
I have a Ice-o-matic, model number IC1006FAZ, the purge valve gets stuck after one harvest, it got stuck open, we open it and clean all the hoses, and unclug the valve, It happened before and it fixed the...
Pretty sure it is a bad valve. You can unplug the unit and disconnect the wires to the purge valve then plug the unit in again and try to make ice like that. If the valve leaks through with no power it is obviously bad. You note that you unclogged the valve in the past. I have taken a few of these apart and sprayed the internal diaphragm with food grade silicone lubricant but this is a very short term fix. I always wind up ordering and replacing the valve.
In the mean time you could plug the purge hose for a day or two. I would not run it too long like this because you will get a mineral build-up in the unit. The reason for the purge is that minerals do not freeze and wind up settling in the sump. Eventually enough mineral deposits build up to circulate and clog up the water tube and deposit on the evaporator plate. Some minerals are always going to stay in there and cause problems but with no purge they will REALLY build up.
Aug 18, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
ICEU220HA1 ice machine is half full of water - water fills up through drain hole in the tub when cleaning/purging pump
You have a restriction in the drain line beyond the ice machine and the water is backing up into the unit. You can try some Drain-o or snake the drain.
Apr 21, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice maker is working, but there is water in the bottom of bin
You will need to pull out what ice you have in the bin to get to the drain. Once you have done that, take a hose and force water thru the drain. You may have to snake the drain if is more than a build-up of ice. Once the drain is working, clean out the bin with ice machine cleaner and sanitizer. Restart the machine and make sure no water is dripping from the evaporator above. If there is, it needs to be cleaned.
Nov 07, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
I have an ice machine (Ice O Matic) Mod # EC1406HPB2 print # 9071919-01. that runs for approximately 10 mins, than compressor stops, I replaced start and run capicators, same problem. am thinking the Hi -...
You have to remove the bin to access the inner workings and the hi-temp safety is strapped to the suction line. You just look for two black wires disappearing into the line insulation to find it.
To remove the bin you: 1. Unplug the unit. 2. Take the top off and remove the sliding bin door, 3. Remove the front bottom louver, 4. Look straight back and disconnect the drain hose from the bottom of the bin, 5. In the louver opening look in the top corner and there will be a screw in each side going straight up into the bottom of the bin. Remove these two screws and lift the bin up and out.
If you are going to run the unit with the bin off you will have to cover the condenser area so that the air is forced over the condenser and be prepared to catch any ice that is produced.
Aug 08, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
1,299 people viewed this question
Top Ice Kitchen Appliances - Others Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
ray gallant
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
