Question about Playmates My Life Handheld
How many batteries does a My Life need?
I'm trying to remember how many batteries it needs, cause I'm looking @ getting one myself.
3 AAA
Posted on Jun 18, 2009
Where i can replace the battery of my Casio watch,.Casio hunting timer AMW 705
The battery of my Casio 1846 W-71 was dead, so I tried to replace the battery by myself.
First, you need to get a hand on a CR2016 3-volts battery. It could cost you 5$ or 10$, but I got 5 of them for 1.50$ at an electronics discount store...
Get a precision screwdriver, remove the 4 screws. Be careful when you remove the cover, there's a tiny spring. Remember where it is, then remove it. Remove the watch from the shell.
Using a flat mini screwdriver, remove the cover that holds the battery. You'll need to unclip all 4 corners. There are centers to unclip too, not sure if there was 2 or 4 of them.
Remove the battery, place the new one. Clip the battery cover back, and put the watch back in the shell.
I closed the cover. The watch was showing time, buttons were working, but no sound at all. Looked on the Internet, and read that you need to short circuit it.
Look carefully, there is a label "AC" near a small hole. (Inside the hole you'll see the gray spike of a welding). Just touch something metal inside the hole (e.g. the welding spike) and then touch the positive (top) side of the battery. Put the cover back in place, press a button and listen for the beep.
Screw the cover back in place.
Aug 23, 2013 | Watches
Need replacement o-ring for water tank cap
This is a posting from someone other than myself...however, it presented a good solution.
A solution to the problem with the fill cap failing/leaking. It was/is not the cap, it's the gasket/grommet/o-ring. Remember "THE MAGIC BULLET", well the gasket, that's where you tighten the top to the bottom, some are white and some are black, THEY FIT the Honeywell HWM450!!! ------- Problem solved.
SEE EBAY: NEW AUTHENTIC MAGIC BULLET 4 REPLACEMENT GASKETS SEALS
Recommended:
Yes
Amount Paid (US$): 45.00
Battery Life: N/A
Noise Level: Almost noiseless
Dec 24, 2010 | Honeywell HWM-450 4 Gallon Humidifier
Does my LG phone battery eventually have to be replaced?
hi, all phone batteries need replacing eventually usually after about 12months or so, the best way to ensure you battery lasts long is to let it go totally flat so that the phone wont even light up if you do this once a month and then do a full recharge this will ensure you battery is kept at its best and doing this prevents bad cells forming and prolongs the life of the battery.
if your having battery problems then get it replaced if its fine just remember to let it go totally flat once a month and this will then prolong the life of the battery and you should not need to buy one for couple of years.
i hope i have given you the info you was looking for
let me know if you need further assistance ok
Aug 20, 2010 | LG enV VX9900 Cellular Phone
Why would a daily recharge be needed?
Because it isn't made of the best battery cells,there may be some memory effect with it.Get more tips for prolong battery life.
Apr 16, 2010 | Motorola Mobility BT50 Cellphone Battery
I am trying to see is there a way to charge a sp battery withut the charger and also any tricks for it like hacks?
you will need to know the voltage of the battery and get a charger for that, if not use a DC power supply, remember that it weakens battery life
Oct 25, 2009 | Nintendo Game Boy Advance SP Console
Built-in Battery
get new battery put it in camera and set settings again, but first try charging the battery, this might be all it needs, hope this helps.
Aug 01, 2017 | Konica Minolta DiMAGE Z10 Digital Camera
Battery charge is finished very soon without even using it( in about 5 hours)
The proper way of charging the battery on your phone is by waiting for your phone to indicate that it's running out of powe but not completelyr, if you frequently charge your phone even if it's not yet necessary(battery life indicator show half-way) the ability of the battery to store power will deminished hence the battery life is shorter. Last resort would be trying another battery unit to test if it's your battery of your phone that's causing the unsual battery drain.
Or you can try the following steps on conserving your phones battery life;
  • Turn off your Infrared and BlueTooth when not in use. Even when they are not in use, they do keep drawing power looking for signals.
  • Switch off the vibration alerts. Vibration causes a lot of power usage thereby making battery drain fast.
  • Re-adjust your screen brightness to around 50%. Screen power is another silent killer.
  • Usually, presetted Backlight durations are of pretty high order, this can be readjusted to get more from your battery. Try reducing the Backlight duration.
  • Often we don’t understand that playing games requires Light, Sounds and Shakes. This in turn leads to tripling of battery drainage.
  • Lower Ringing and other message sounds. This too helps saving a lot of battery.
  • Finally, do charge your battery before it gets drained fully. This enhances battery life.
May 05, 2008 | Sony Ericsson K800i Cellular Phone
Help
Hi, You problem is more than likely a faulty battery or even the charger, you'll need to get these tested to find out what is causing the problem.It is known that the batteries tend to stop charging and need replacing after so long. If you take it into any computer shop they will tell you what is causing the problem as they will have a battery to try, this will tell you if it is the battery or the charger that is at fault. They won't charge you for this as it will take a matter of seconds to test the battery.
Let me know if you need further assistance, remember to always let the battery go totally flat at least once a month and then do a full charge as this will prolong the life of your battery and keep your battery lasting for the maximum time. It is recommened to do this with any electrical equipment that works off a re-chargeable battery, or else it cause bad cells & stops it from being charged.
Apr 25, 2008 | Computers & Internet
Nokia 6680 charge problem
with respect to your low Nokia 6680's low battery, what you need to do is to charge it while switched off for atleast 12 hours.  It is possible for the phone to have 200+ standby time afterwards but that is if its not used at all. You should also disable the bluetooth, as well as the backup ligthing if switched on as all these can dramatically reduce the life of the battery.
Sep 23, 2007 | Nokia 6680 Handheld
Playmates My Life Handheld Logo
51 people viewed this question
Top Playmates Toys Experts
ray gallant
Are you a Playmates Toy Expert? Answer questions, earn points and help others
