Back to:
Tags:
Ricoh Aficio 1013F Copier
Text "ghosts" or shadows
posted by Tarnsnut on Oct 19, 2007
Hi there.
When we print ... a very faint copy of the printed dark text is printed about 1/2 way down the page.
Anyone know what's causing this?  We've lightened the density already.. the problem still occurs.
Thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 21, 2007
FixYa! (100)
Soulvisitor
Rank:Guru Guru
Rating: 88%, 1476 votes
Replace Drum or blade(if possible) will fix on most types of copiers/printers, or rarer it is cause of fuser.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Text "ghosts" or shadows:
I don't want to Accept this solution
Can you Help with these Copiers problems?
Copiers
Sir, I have sharp AR-5316 copier, I have a problem with...
Copiers
I have a Risograph RZ220 with the code d--13 --9. The...
Copiers
how to reset the copier thanks chris
Copiers
Everytime i try to make a master copy,it didn't makes a...
I bought a preowned copier yesterday, Konica 12 which...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
