Question about Rainbow 75th Anniversary Canister Vacuum
Rainbow SE vacuum cleaner has no power
We bought our Rainbow SE vacuum ten years ago. We only used it twice the first year that we bought it. Unfortunately the power nozzle and the bottom plate were not working well. We had them replaced because they were still under warranty, but our representatives never gave us the replacement parts. As a result, the vacuum was just sitting in our house for the last ten or more years.
Today, we decided to take it out for a clean on the windows and furniture; however, the power is not on. As we already turned the on/off switch to on, we heard nothing. There is no power.
Does anyone know what's wrong with it? If we are to repair it, how much would it cost?
Thank you
Rainbow just stopped running. Acts like no power. Electrical plugs are fine
  • champion1954 May 28, 2009
    Thanks this will get me headed in the right direction.
    Brigadier General:
  • 8,619 Answers
Hi
If it doesn't have any power then its an issue with the power board of your rainbow vacuum or the motor. You'll need to disassemble the vacuum to look for any loose connections or burnt components. If everything inside the vacuum looks fine then check for input power coming to the vacuum and to the control board. If the power is there then the motor has gone bad else the control board is faulty and you'll need to replace it. You can buy the parts for your Rainbow Vacuum from this link---
Rainbow SE vacuum cleaner Parts link 1
Rainbow SE vacuum cleaner Parts link 2
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 23, 2009
2 Suggested Answers
  • 114 Answers
SOURCE: Rainbow SE vacuum cleaner has no power
Invert the vacuum cleaner without the water tray installed. With the machine unplugged, give the separator a spin clockwise. If it spins easily, this is a good sign. If the bearings are good on an SE, you should hear the faintest of rapid clicking sounds as you spin the motor. This is the sound of the brushes as the commutator segments pass under them. The brushes on SEs will sometimes hang up and not make proper contact; they are too precise a fit in their holders and the carbon dust they generate plus a tiny bit of moisture will cause them not to extend as they wear. When this happens, the brush tension spring overheats, relaxes, and it's time for new brushes and a service. Anyway, if you determine that the motor is turning smoothly (resistance or binding indicates bad bearings), install the water tray dry, plug the vac in, switch on, and give it a couple of bi__ch slaps with the palm of your hand on the side of the vac near the top. This can sometimes free up a stuck brush but the effect is likely not to last. It will, however, give indication of whether the machine might run or not after a fairly cheap repair (under 100 dollars).
Posted on Dec 22, 2009
How do I replace the fuse on a rainbow vaccum?
The D4 model Rainbow has a Thermal Cut Off
This has to be manually replaced. It is attached to the Field 120v D4
If this has blown, then most likely something is causing. The Armature Tall 120v D4 could be going bad.
You can also speak with our technical support team Contact Us
RainVac
Jan 27, 2016 | Rainbow D4se Classic Canister Vacuum...
How to get to the rainbow SE vacuum off/on switch.
Hi, here is a walkthrough on how to get to that part here. Steps 1 - 14 on how to access it, you will need to take apart the housing to get at it. If you need a new switch you can find that here. Rainbow did redesign this switch, so you will need to look at the wiring diagram if you are installing a new switch.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 18, 2014 | Rainbow Vacuum Cleaner Power Switch D3,...
Our Rainbow SE PN2 is blowing instead of sucking, is there some kind of airflow adjustment that we need to do?
Kellie, I've had 2 Rainbows and the only way I know that they can blow is if you have your hose attached to the outflow(exhaust) for such things as blowing up air beds water toys, etc. If your hose is on the front of the machine and it is still blowing air....I got nothin'! That seems very odd to me, and I've never been told even when I sold the machines that there was any type of airflow adjustment for them, especially on these older models.
Sep 21, 2013 | Rainbow Reconditioned Canister Bagless SE...
I bought my rainbow se vacum 4 years ago and I was using it and suddendly stoped working, I try to on no power I on and off not working at all. what shall i do is there posibility to work again.pls.help...
Hi, there is no reset button on a Rainbow vacuum.
All SE series vacuums have a built in thermal and load fuse on the motor, and if it blew, it has to be replaced, or wired directly, with out it on there.
Motor brushes are usually the source of a non working Rainbow D4 and SE and all model Rainbow vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature. It is probably the thermal and load fuse, that is your problem, if you did not smell any electric burning type of smell, before it quit. It could be the power switch, but not as likely as the fuse. If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Feb 13, 2010 | Rainbow 75th Anniversary Canister Vacuum
How to maintain up keep on my rainbow vacuum
Be sure and never store on water basin, keep separator and seal on bottom of rainbow clean. Keep your beater bar clean. You should be good for many many years.
Jul 10, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Apr 04, 2009 | Rainbow 75th Anniversary Canister Vacuum
Replace power cord
http://www.rainvac.com/schE1.pdf
Jul 17, 2008 | Rainbow 75th Anniversary Canister Vacuum
How do I remove the pin on my Rainbow Vacuum Model SE clips?
When I used to repair Rainbow SE vacuums for a living, I had a long nail of small diameter that I had filed the end off of just for this purpose. The pin you need to remove is grooved on each end to "catch" in the plastic housing, but a slight tap with a hammer, using this "nail" will do the trick. When you're ready to re-attach it, just tap it again to put it back in place.
Apr 04, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Tristar***mg1
Looking for owners manual for a Tristar MG1.
Feb 17, 2008 | Vacuums
Rainbow 75th Anniversary Canister Vacuum Logo
362 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
