Question about Ovens
What is the wattage of this unit?
Can anyone tell me the wattage of the AEG D21005?
  • jennyabourne May 24, 2009
    Thanks, but we have not got the oven yet. The electrician who is going to fit it needs to know now.
  • Ovens Master
  • 3,361 Answers
Look on the spec plate for volts and amps. Multiply volts times amps for watts.
Posted on May 23, 2009
My AEG oven needs a PC board, but I cannot find where I can buy one. Can anyone help pleases?
PCB for D5701-4-M is obsolete. I certainly could not find one. Alternative is repair. I used QER Ltd via ebay. Involves removing and identifying part number of board and ordering repair via ebay listing. The trick is to find the correct listing for your board number as it will not be listed under AEG D5701-4-M. For instance, my D5701-4-M, part no. 944171390 (found on plate in bottom right hand corner of main oven) uses board NPPUGN104. It was listed in ebay under Repair pcb / module Zanussi Z0B1060X. Took two attempts to fix, but so far so good.
Nov 19, 2012 | AEG D5701-4 Electric Double Oven
Oven Light Assembly wires
does not matter.
Jan 22, 2012 | AEG Ovens
I have an AEG B3101-4 oven that wont turn on, could a fuse be blown inside the oven?
first check the power to the unit itself, to be sure the house power is on , if the unit is totally dead,, then remove the back to locate a fuse that will be just next to the incoming line, check both of these items with a volt meter if you feel thats something you can do.
Jul 13, 2011 | AEG B3101-4 Electric Single Oven
The light on my aeg competence oven and grill is not working. I can not use the timer.
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
http://www.espares.co.uk/part/cookers-and-hobs/thermostats/aeg/p/1604/143/0/0/1061574/top-oven-thermostat.html
May 20, 2010 | Ovens
Aeg b4101-4 cooling fan for electronics does not turn off.
Probably have a thermostat inside the space that is bad telling the fan to stay on . If you cant find thermastat which I believe you can at appliance repair shop just hook up a switch to the fan.
Jan 18, 2010 | AEG B4101-4 Electric Single Oven
Aeg single oven
You need to reset the timer to manual from auto , that is why your oven won't come on.
Refer to your user manual on how to do this.I can't tell you how as the sequence differs from model to model.
Plz leave feed back for this solution.
Thanks.
Dec 11, 2008 | AEG B1180-4 Electric Single Oven
Wattage for oven pleb30s9fc
  • Connected Load (kW Rating) 240/208 Volts: 3.5/2.6
  • Amps @ 240/208 (Approx.): 14.6/12.6
  • Minimum Circuit Required - Amps: 30
  • Bake Element Wattage 240/208 Volts: 3400/2554
  • Broil Element Wattage 240/208 Volts: 2750/2065
  • Armored Electrical Cable
What kind of wires did you buy?
Jul 25, 2008 | Frigidaire PLEB30S9DC Electric Single Oven
Ovens Logo
90 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
