Question about DeLonghi DFH2550TB Compact Heater
How do you clean with a heating element?
How do you clean my
DeLonghi DFH2550TB
with a heating element inside of it?
  • 625 Answers
It has to be taken apart and you need to blow compressed air through the front. dust particles get trapped between the fan and the heater element.
Posted on Nov 10, 2007
My dishes are not getting clean, the plastic has a grease fill on it the glasses have food residue stuck to them on the inside. I had to put the glasses on the bottom shelf in order to clean them but that...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 15, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
There has been a trail of dry soap on inside of door after wash is complete, also dried soap on some dishes in bottom rack as well as not being clean and on top rack spots on glasses and sometimes some...
A bad heating element causes many problems in dishwashers…
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 28, 2010 | Hotpoint 24 in. HDA900X Built-in...
Dryer runs but stopped heating.
Please check if the lint filter inside the machine is clean as if it is clogged with lint there is no circulation of air. Actually this filter must be cleaned after every operation. If this does not solve the problem check the wiring connection of the heating element. Possibly there is no link. So the heating element is not getting any power
Jan 30, 2010 | Dryers
Heating element turns bright orange, gas does not ignite
you need to replace the primary and secondary gas valve coils on the top of the gas valve located inside the machine which will require you to remove the top cover and front panel to access the coils
Jan 02, 2010 | Dryers
DEIX2 does not dry - cleaned out lint trap, disassembled and removed lint from around lint trap assy., still not drying
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jul 22, 2009 | Fisher and Paykel DEGX2 Dryer
Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Jul 08, 2009 | Fisher and Paykel DEGX2 Dryer
Water level below heating element and element does not appear to heat
Make sure the drain hose high loop is installed properly, normally you have this in the sink cabinet high up. Otherwise the water inside the machine may drain "by itself", leaking through the inactive drain pump during the wash cycle and cause this and other troubles.
May 24, 2009 | Kenmore Dishwashers
Dishwasher not cleaning properly but seems to be working ok
The main cause of poor cleaning when the heating element is not working is a failed heating element inside the base (sump)
A technician will be able to use a multimeter to check the element resistance.
Once the element is working again, I recommend that you use a brand name dish washing powder like Electrosol and Cascade. Never use a gel or tablet. Avoid cheap detergent.
Mar 30, 2009 | Electrolux Dishwashers
GE range - oven stopped working after cleaning
If you bent the bottom element out list out of the way, you may have broken the actual heating element inside of the metal sheath. Or, it could have shorted to ground.
After tinkering with it more, you might have caused another short, and now both legs of 220 VAC have either a blown fuse or tripped breaker.
Reply what you find is the sondition, and I will help you troubleshoot more.
Jan 24, 2009 | Kitchen Ranges
DeLonghi DFH2550TB Compact Heater Logo
66 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
