No sound coming from tape dec, though tape is turning
(TEAC single cassette deck v-377)No sound comes from dec when play button is pressed. Tape winds ok. Have checked all leads etc.., tried different tapes and cleaned heads. The problem appeared suddenly without warning the last time I tried listening to a tape. Dec has not had excessive use and is probably about seven years old.
  • Audio Player... Master
  • 1,267 Answers
This sounds like the shorted 10 V electrolytic capacitor symptom.
A technician will need to find the shorted capacitor and replace it with the same value but a good 16 V cap. The 10 V caps were known to fail a lot in some equipment.
Posted on May 08, 2014
  • 5,487 Answers
First check the wires going to the tape heads make certain they are connecting. If good follow them and see if they go to any micro switches, if still no joy keep following the leads to the PC board. The best way to test is to poke around and see if you get any buzz on any of the pre-amp parts. Work back from the output sockets of the deck to where the head wires join. If you get a buzz after and not before you have located the faulty stage.
Don't touch the power supply parts!
Posted on Jun 26, 2009
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Record button wont press down
Record button can be pressed down only if you placed a cassette into the deck and if this cassette was not protected against recording. This protection is mechanical, and can be found at the top of the cassette. One for the A-side and another one for B-side.
Thanks,
gylacz
Feb 01, 2014 | Teac W-505R Single Dual Cassette Deck
My Play, Pause, and Record button will continuously blink on and off, which prevents me from opening the cassette door using the eject button to play a tape.
That would be me at Skywave Tape Deck Repair- maybe I have contacted you already through Thumbtack.
I can not say more here but if you search for tape deck repair in Chicago you no doubt will come across me sooner or later.
The only other person you would be qualified would be Russ Bachmann at New Jersey Factory service. We both worked at Teac factory service facilities and rose to high ranks at those facilities.
Jan 18, 2013 | Tascam 122MKIII Single Dual Cassette Deck
I have a TEAC W-450R Stereo Double Reverse Cassette Deck. For some reason, the REC/PLAY II side will not operate. It has not for some time. In fact, that is why I believe I mothballed it some years ago....
I have not seen those to a large extent due to their value not being worth a repair. I did work on them at Teac though. The capstan motor of the right side deck sound like it is burned out. I have some motors here so it is just a matter of if you want me to work on it or not. I get a lot of units in all the time- I am Skywave Tape Deck Repair in Chicago area.
Feb 22, 2011 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Tape players wont play the tapes. THey are turning but no sound is coming out. checked all connections and can't figure out whats' happening. Technics model RSTR72. Is it worth fixing or should I get...
you have two buttons B+C USE B to get sound to your speakers if no joy try a simple tape cleaner or anti static tape cleaner this is usually the problem.
Dec 19, 2010 | Technics RS-TR272 Single Cassette Deck
TEAC CX-370 Cassete Deck
Could be a worn out belt? The cassette loads it the drive down too much. Hence why it turns with no tape.
Jul 04, 2008 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Teac w 600 r tape deck
PUSH DUB BUTTON HIGH SPEED OR NORMAL
Aug 14, 2007 | Teac W-600R Single Cassette Deck
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Jun 22, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
 Grubhead
Grubhead
