No display
After all your troubleshooting, I think this is likely to be as a result of your processor over-heating, maybe because of your environment, or because the fan is not cooling the processor properly again. Therefore my suggestion would be for you to unscrew your system (If you can do it by yourself), and try to clean, or better still replace your processor fan.
If you cant do it by yourself, you can easily get a technician to do it for you. This solution is actually if your processor is not yet burnt.
But if your processor is burnt, then you might have to change it to a new compatible one. but before changing it, try to test the motherboard with another working, compatible processor first, just to be more sure.
Then always make sure that your PC is in a well ventilated, cool environment and that the environment is free from dusts.
Hope this helps you out.
